Thread Number: 85704
Maytag HE toploader white film on darks (MVWC565FW) |
Post# 1102661 , Reply# 1   12/31/2020 at 13:10 (1,211 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1102678 , Reply# 2   12/31/2020 at 17:12 (1,211 days old) by eronie (Flushing Michigan)   |   | |
I agree not enough detergent !!! No cold washing either !! You must use at least use body temp water to suspend body oils, I think that's what is attracting the lint !! |
Post# 1103354 , Reply# 4   1/6/2021 at 03:38 (1,205 days old) by mrboilwash (Munich,Germany)   |   | |
Picture #2 looks more like cold chicken broth than rinse water in a washing machine.
Just look at all the grease and scum floating on top. Instead of cutting back from line #1 you could try to step up to line #5 or even more until the problem is solved and maybe you should use hotter water too. On a load like this I`d start with a full cap and watch the progress of the wash cycle, adding more detergent as needed until there`s a nice layer of suds. Additionally you could try to cut out liquid fabric softener if you use any. Fabric softener per se is no problem, but if you use way too little detergent to dissolve all body oils the remaining oils could form some type of soap scum with the FS. This post was last edited 01/06/2021 at 03:54 |
Post# 1103360 , Reply# 5   1/6/2021 at 06:25 (1,205 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
i would also advise not using fabric softener and i would suggest if you have the clean washer cycle on your machine it will remove any residual dirt or build up as well as run your next load using hot water and also check if the water in the machine enters hot and is not mix with cold water because of the atc temp sensor
