Thread Number: 86024
/ Tag: Wringer Washers
Help identifying model of Maytag wringer washer |
Post# 1105858 , Reply# 1   1/25/2021 at 23:39 (1,186 days old) by bradross (New Westminster, BC., Canada)   |   | |
The power unit, legs and base/frame is from a Model 90. The wringer and tub are from a Model 30. (Model 90 tubs were two pieces, with the top riveted onto the bottom, and there was no "bead" around the top or bottom.)
Also, the serial number is missing the letter after the number. That is what indicates the month/year of manufacture. Apparently, the previous owner erased that somehow. Also, the previous owner would have had to have drilled a hole on the top right of the tub's crown to accommodate the shift lever. |
