Thread Number: 86078
/ Tag: Modern Dryers
Another Coin-Op Question - CEM2940TQ1 |
Post# 1106450   2/1/2021 at 14:44 (1,180 days old) by DADoES (TX, U.S. of A.)   |   | |
Complaint that it won't take coins (presumably jammed mechanism). No problem when I tested, coins dropped right through (slide return springs are broken, doesn't affect the drop). The start button is bad, continuity across CO/NO terminals without pressing. Dryer starts immediately upon 1) engaging cycle with coins, 2) closing door after opening, 3) disconnecting/reconnecting power cord. I disconnected the NO wire to confirm ... doesn't start until touching the NO wire to the CO wire/terminal. Now, it never shuts off. Been running for probably 4+ hrs. The timing cam (45-min cam) rotates so presumably the timer works. I didn't notice if it turned prior to disconnecting the NO wire but it does for sure with the wire disconnected. Is there a way to manually turn the timer to Off? How long is the full possible cycle duration? |
Post# 1106522 , Reply# 1   2/2/2021 at 12:15 (1,179 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1106843 , Reply# 2   2/5/2021 at 08:29 (1,176 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1106859 , Reply# 3   2/5/2021 at 10:15 (1,176 days old) by Repairguy (Danbury, Texas)   |   | |
