Thread Number: 86138
GE Slow Fill |
Post# 1107049 , Reply# 1   2/6/2021 at 19:13 (1,174 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1107119 , Reply# 3   2/7/2021 at 11:24 (1,174 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Is it flushing the detergent dispenser properly? Best would be to pull off the top and check where that nozzle goes to? |
Post# 1107120 , Reply# 4   2/7/2021 at 11:25 (1,174 days old) by DADoES (TX, U.S. of A.)   |   | |
Filling on a frontloader is normally, primarily, through the dispenser drawer, with a diverter mechanism or multiple solenoids involved to direct the flow through the various cups at the proper time (detergent, bleach, softener). The little nozzle is not likely the main flow route. You didn't cite the model number of the machine for parts diagrams look-up to see what all is involved. |
Post# 1107124 , Reply# 5   2/7/2021 at 11:33 (1,174 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Manualslib has several service manuals. The one I pulled has 2 valves and a 4 way diverter. The hose to the front goes off of a connection to the drawer. Don't think much water should come from there. But that was the TOL model with some sort of bulk dispenser system. So telling us a model number would help. |
Post# 1107129 , Reply# 6   2/7/2021 at 12:27 (1,174 days old) by bradfordwhite (central U.S.)   |   | |
If you take the top off you should see all the hoses and valves.
Take a picture so you remember where everything was. Then take the pieces out and clean. You might just need to soak plastic pieces in vinegar to get rid of lime build up. There might be a blockage in one of the solenoids from the previous persons bad plumbing. |
Post# 1107158 , Reply# 8   2/7/2021 at 17:24 (1,173 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Supposedly yours has a steam generator. The pipe appears to be related to that. How did you run cleaning cycles of it doesn't fill? Here a link to your service manual: CLICK HERE TO GO TO henene4's LINK |
Post# 1107189 , Reply# 9   2/7/2021 at 21:43 (1,173 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1158675 , Reply# 11   9/4/2022 at 18:29 (599 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
