Thread Number: 86412
/ Tag: Wanted to Buy Items
Antique GE fridge parts wanted as well as restored antique gas stove |
Post# 1109913 , Reply# 1   3/1/2021 at 12:44 (1,152 days old) by RP2813 (Sannazay)   |   | |
That's a very nice refrigerator! The pink interior color scheme was new for 1957 on the two-door Combinations, which is the type I had for almost ten years before the compressor developed a fatal problem. I think GE kept the pink interior on the single door models for 1958 but the two-doors changed to a pale aqua.
Your best bet for parts is likely a donor fridge that's no longer in working order and could probably be had for free. Harvest what you need from it and then send it off to start a new life as a Prius.
Post# 1109929 , Reply# 2   3/1/2021 at 14:59 (1,152 days old) by donvwdon (Rhode Island)   |   | |
Thanks for your suggestion re. donor fridge! Now I just need to find one nearby. |
Post# 1109987 , Reply# 3   3/2/2021 at 07:22 (1,151 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi, you would be better served with something built after WW-2, ranges got better and better into the 50s through the 60s, the quality and durability was so much improved.
By and large the pre-war stuff did not last as long and consumers dumped pre-war ranges in droves in the 50s and 60s for the newer ranges that worked better and lasted longer and were easier to clean due to better finishes etc., When you look at the insides of those 30s and 40s ovens they were usually nothing but rust because of the poor quality finishes.
There are certainly some exceptions to my advice, but I think you will have better luck if you look for something closer to the age of your GE refrigerator.
Post# 1109993 , Reply# 4   3/2/2021 at 08:50 (1,151 days old) by Northwesty (Renton, WA)   |   | |
is wrong with the vegetable drawer? |
Post# 1110003 , Reply# 5   3/2/2021 at 12:11 (1,151 days old) by RP2813 (Sannazay)   |   | |
