Thread Number: 86629
/ Tag: Vintage Dishwashers
KDS-18 with drain problem |
Post# 1112292   3/21/2021 at 23:09 (1,130 days old) by gregingotham (New York)   |   | |
Looking at an CL ad for a KDS-18 and it says it won't drain properly. What can be typical causes of that and is usually easily fixed or could it be a major problem? |
Post# 1112305 , Reply# 1   3/22/2021 at 07:07 (1,130 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi greg, these are usually pretty easy, either a clogged drain valve, bad DV or a broken drain Impeller in the pump. [ or household problem like a clog in the drain line ]
If you are going to use a used KDS-18 DW you probably should be taking the drain pump apart and inspecting the main seal and probably replacing it anyway.
Post# 1112397 , Reply# 2   3/22/2021 at 18:38 (1,130 days old) by gregingotham (New York)   |   | |
is it hard to find replacement racks for these? the racks are pretty heavily worn...might be hard to fully repair. Looks like its been in constant service since the early 80s |
Post# 1113434 , Reply# 3   4/1/2021 at 09:42 (1,120 days old) by gregingotham (New York)   |   | |
John-the owner says he's checked the drain, pump, etc. He thinks it may be the timer that's causing it not to advance and drain. Is that possible? |
Post# 1113435 , Reply# 4   4/1/2021 at 09:55 (1,120 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1113507 , Reply# 5   4/2/2021 at 01:55 (1,119 days old) by rollermatic (cincinnati)   |   | |
guess that it's either the drain valve itself or possibly a disconnected or loose wire to the drain valve solonoid.
i also agree in that if you are planning on using this machine on a regular basis a new pump seal would be the best thing to do, tune up wise. you can get em on ebay, i bought a couple last year and rebuilt a kds-18. i'm sure they are still available and i can get the part no if you want it. dont know it offhand but i can check my seals and find one. i have a lot of kitchenaids of various models (about 24) and i have never run into a timer problem yet. it's probably something simple like a loose wire. good luck with it if you get it, we can help you change that seal also. lot of good info on this site. |
