Thread Number: 86696
My year 2000 Kirkland washer I acquired yesterday.. |
Post# 1112813 , Reply# 1   3/26/2021 at 18:56 (1,126 days old) by DADoES (TX, U.S. of A.)   |   | |
The bleach dispenser drains into a tray on the tub ring that in turn drains immediately into the outer tub so bleach dilutes with water. The outlet port on the dispenser apparently is clogged. It can be snapped out of the top ... very carefully or one or more of the little tabs that anchor it typically will break off. Better to poke into the outlet with a wire or toothpick or cotton swab to clear the clog. |
Post# 1112814 , Reply# 2   3/26/2021 at 19:00 (1,126 days old) by ps91Rick (Lancaster, Ca )   |   | |
Thx! Mine must have broken tabs already as it comes out easily and moved if bumped .. I believe mi r is clogged be the removable tray.. |
Post# 1112827 , Reply# 4   3/26/2021 at 21:26 (1,126 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Have lots of fun with her. These are good performers. |
Post# 1112832 , Reply# 5   3/26/2021 at 22:48 (1,126 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 1115687 , Reply# 7   4/27/2021 at 00:51 (1,095 days old) by Yogitunes (New Jersey)   |   | |
just out of curiosity, this may be one of the odd dubbing temp versions....
meaning, if you select HOT, it will fill with that temp for 60 seconds, and then switch to WARM or COLD for the rest of the fill....I thought there was something wrong the first time I encountered this...and found out it will only restart this sequence after a full cycle... there are little tricks they throw in there..... as well as some machines offer a WARM rinse, but its not the deep fill that is WARM, its the final spray rinse that is WARM.... there are vids on replacing the 'dogs' inside the agitator, one of those will show you complete removal, tear down, and replacing all the parts inside....easier than you think...there are changes to some, but the general internals are all the same.. |
Post# 1115689 , Reply# 8   4/27/2021 at 00:57 (1,095 days old) by ps91Rick (Lancaster, Ca )   |   | |
This one definitely has full hot.. its worked fine up until recently. As for the agitator, i rebuilt mine for $20 and its working well.. Thanks! |
Post# 1115701 , Reply# 9   4/27/2021 at 08:24 (1,094 days old) by DADoES (TX, U.S. of A.)   |   | |
Parts diagrams show that it should have an electronic temp control board. Probably is plugged into a socket in the console if it does. P/N 3407125 which is NLA but can be found on eBay. They do go bad but it may or may not be the problem.
