Thread Number: 86697
/ Tag: Vintage Dishwashers
GE GSD2304K00WW just a tiny bit full. |
Post# 1112823 , Reply# 1   3/26/2021 at 20:27 (1,126 days old) by appnut (TX)   |   | |
Post# 1112837 , Reply# 4   3/27/2021 at 00:23 (1,126 days old) by Awooff (Peoria, Illinois)   |   | |
Nice loading! - a tower wash system is best underloaded imo. -id try the big pot placed in center of upper rack and never have tried seventh generation but cant imagine it being better then ordinary powdered detergent.
Does not look like u need rinse aid, per the spot free glass lid - unless maybe the rinse aid dispenser still has plenty of rinse aid in it... Pic #2 is not glass etching! Looks like an expensive knife was run across it to me.. |
Post# 1112838 , Reply# 5   3/27/2021 at 02:22 (1,126 days old) by toploadloyalist (San Luis Obispo, CA)   |   | |
Does that dishwasher have a 'Pots & Pans' cycle selection, or anything close to that? |
Post# 1112845 , Reply# 7   3/27/2021 at 07:40 (1,126 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Thanks for sharing your experiences Tom, and you proved even a DW with a center tower is better than no DW by a long shot.
I always put all my cookware in the DW which keeps it from getting any build-ups on the outside, bottom etc.
Large packed loads certainly show the limitations of a center pop-up wash tower system, GE is probably the only DW that still takes this short cut on their basic models.
I would to see your results with one of my late 80s WP Power-Clean DWs, I wash packed filthy loads like yours every week and almost never see a speck of anything left behind.
Post# 1112849 , Reply# 10   3/27/2021 at 08:30 (1,126 days old) by Awooff (Peoria, Illinois)   |   | |
A quarter of the way through the wash cycle here would be the main wash portion of the whole cycle. -At this phase is when the main detergent door dumps its detergent and also when the option of pots n pans should be increasing the water temp to around 140f - non pots n pans option would only insure around 120f
Although if your incoming water temp is very hot then any dishwasher may not have to "pause" the main wash portion to heat water to 140f. If you can get the model number off of this machine, then an owners manual will explain cycle sequence. Ive found dishwashers with a temp raised main wash to do better with cooler incomming water as then the machine will run longer during the main wash portion while it heats the main wash water to 140f |
Post# 1112891 , Reply# 12   3/27/2021 at 13:52 (1,126 days old) by Awooff (Peoria, Illinois)   |   | |
Your probably correct on normal cycle as this would be the cycle judged for energy star compliance!
My old electronic kenmore ultra wash sensor normal cycle has only 3 water changes total with last 2 being rinse - if both detergent cups were to be filled then the cup opens at 68 minute mark (if memory serves) or half way thru main wash portion (last 2 fills are rinse) - many times for normal i only fill the open cup essentially |
