Thread Number: 86716
Speed Queen AWS412-Loud Clicking on Wash Cycle |
Post# 1113031 , Reply# 1   3/28/2021 at 15:22 (1,125 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1113139 , Reply# 2   3/29/2021 at 15:34 (1,124 days old) by disklxik (Gardena, CA)   |   | |
Is there a photo reference or instructions somewhere to guide the lubrication of the brake pads? Thanks |
Post# 1113167 , Reply# 3   3/29/2021 at 20:33 (1,123 days old) by Repairguy (Danbury, Texas)   |   | |
I don’t believe I’m familiar with the model number posted. I probably do the job the hard way but it’s always worked great for me. You should use a silicone grease and I recommend sil glyde which is designed for this application.
Remove 2 screws in the lower portion of the machines front panel. Slide the belt off of the large pulley by rotating it off It helps to remove the motor assembly but is not necessary There are 3 brake pads secured by 2 screws each from the bottom side Remove the screws from one pad Rotate the large pulley in the direction with the most resistance until it tops out The brake rotor should now release this pad Remove and apply a very minimal amount of sil glyde to the pad on both sides but not on the part of the pad where the screw holes are Wind the pulley up again to release brake rotor and slide pad back in place Reinstall screws Repeat for the other 2 |
Post# 1113186 , Reply# 4   3/29/2021 at 23:39 (1,123 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1113214 , Reply# 5   3/30/2021 at 10:57 (1,123 days old) by disklxik (Gardena, CA)   |   | |
Thanks!!! I'll give it a try! |
