Thread Number: 86749
Maytag tub no fit |
Post# 1113223 , Reply# 1   3/30/2021 at 14:04 (1,122 days old) by LowEfficiency (Iowa)   |   | |
Post# 1113249 , Reply# 4   3/30/2021 at 18:23 (1,122 days old) by Good-Shepherd (New Jersey)   |   | |
Okay that explains it. Probably a member here might have an extra set or find another large capacity donor machine, they were mostly unchanged for decades. |
Post# 1113253 , Reply# 5   3/30/2021 at 18:57 (1,122 days old) by latchlock8111 (Sulphur Springs Tx)   |   | |
Looks like I will be shopping for part # 213053. Times 3. As all I need are the brackets. That should be simple to ship/mail. |
Post# 1113265 , Reply# 7   3/30/2021 at 21:41 (1,122 days old) by LowEfficiency (Iowa)   |   | |
Post# 1113299 , Reply# 8   3/31/2021 at 05:14 (1,121 days old) by latchlock8111 (Sulphur Springs Tx)   |   | |
... thank you for the direction. Lorain guy has it going on .... pricey ye$, but it will save me much leg work ... no pun intended. |
Post# 1113315 , Reply# 9   3/31/2021 at 07:51 (1,121 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
"I pulled up the Maytag parts diagrams I had handy, and the A308 lists these as part #213053, whereas the A408, which I had assumed to be identical, lists them as #313053."
That's odd. A part number beginning with three should be for a dryer, not a washer, unless the part first appeared on a dryer at some point. That's not possible for a tub brace. I wonder if it's just a misprint, since only the first number changed? |
Post# 1114906 , Reply# 11   4/17/2021 at 18:43 (1,104 days old) by Good-Shepherd (New Jersey)   |   | |
Thats not redneck, the Maytag service manual suggests constructing a similar makeshift trans work bench. The Gates heater hose, now thats redneck.. |
Post# 1114907 , Reply# 12   4/17/2021 at 18:47 (1,104 days old) by Good-Shepherd (New Jersey)   |   | |
Make sure you've got the tub bolts in the correct position, short bolt goes in front. |
Post# 1114909 , Reply# 13   4/17/2021 at 19:06 (1,104 days old) by latchlock8111 (Sulphur Springs Tx)   |   | |
... c-clamped to the tailgate of a beat-em-up-pickup truck with over 250k on the milage ?? Short bolt up front, gotcha ... |
Post# 1114918 , Reply# 14   4/17/2021 at 19:54 (1,104 days old) by qsd-dan (West)   |   | |
Post# 1114927 , Reply# 15   4/17/2021 at 20:54 (1,104 days old) by latchlock8111 (Sulphur Springs Tx)   |   | |
Yes new lower seal went in. The base, from the 106 is shown/transplanted. Repainted but 100% rust-free. Just had paint chippin' off. The base off the 408 was way too rusty for my likin'... that got thrown out too !! |
Post# 1116193 , Reply# 17   5/2/2021 at 19:03 (1,089 days old) by qsd-dan (West)   |   | |
Post# 1116204 , Reply# 19   5/2/2021 at 20:56 (1,089 days old) by qsd-dan (West)   |   | |
Post# 1116209 , Reply# 20   5/2/2021 at 22:30 (1,089 days old) by Good-Shepherd (New Jersey)   |   | |
I'm confused. Did you put the machine back together with tub bearing sleeve still seized on the transmission? |
Post# 1116260 , Reply# 21   5/3/2021 at 14:43 (1,088 days old) by LowEfficiency (Iowa)   |   | |
The photo in the post a few up seems to show the sleeve removed, but are there two different transmissions being intermixed here? Are transmission parts being combined from the two machines?
As long as it's in good shape, and of a good dimensional match for the new outer piece, I'm not sure that it's necessarily a problem if the spin tube is stuck to the upper transmission case? (It's not supposed to spin against the case anyway...) |
Post# 1117511 , Reply# 24   5/17/2021 at 19:53 (1,074 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Some brake assemblies just like to make a little err as they come to a final stop, glad you found a good one.
My Frigidaire Uni-Matic has always done this, but nothing wrong with going for perfection, however I place more value on performance and luxury in vintage appliances and automobiles.
