Thread Number: 86856
/ Tag: Vintage Dishwashers
Why Did Older Dishwasher Have Such Enormous Motors? |
Post# 1114196   4/10/2021 at 14:09 (1,124 days old) by chetlaham (United States)   |   | |
I mean why were they so big considering modern dishwashers get dishes clean with a 50 watt motor?
Why not make a two port sump (think plastisol tubs) and add a removable find filter basket? 180 watt wash pump like this:
https://www.ebay.com/itm/GE-Washer-Drain...
And a 25 watt drain pump like this but in shaded pole version:
https://www.ebay.com/itm/GE-WD19X10015-D...
Frog eye or cat eye spray arm with small holes. Continuous advancement timer (like on GE machines) where the drain pump starts and the wash motor shuts off 30 seconds latter. Similarly after the drain pump shuts off, fill starts and 30 seconds latter the wash pump comes on.
I think this would have been cheaper, used less water and reduced carry over water found in many designs.
Why not have gone this route? Speed Queen could pull if off today if we wanted a no frill machine but also respected modern design. |
Post# 1114380 , Reply# 2   4/12/2021 at 03:02 (1,123 days old) by qsd-dan (West)   |   | |
Big motor + lots of hot steamy water + brute force + phosphates + bleach was how the dishes got cleaned in a timely manner.
Whirlpool Ultrawash/Power Clean dishwashers were still using a 1/3 HP motor through 2010. Detergent with phosphates and bleach were available through 2009, so it wasn't all that long ago. |
Post# 1114488 , Reply# 5   4/12/2021 at 22:15 (1,122 days old) by AcesUp8000 (Canada)   |   | |
1/2 Horsepower Motor The KitchenAids from the 15 Series to the 21 Series used the 1/2 Horsepower motor that was made by Hobart. Once Whirlpool took over KitchenAid, I think they eventually made these dishwasher motors weaker. |
Post# 1114572 , Reply# 6   4/13/2021 at 17:55 (1,121 days old) by johnb300m (Chicago)   |   | |
Post# 1114613 , Reply# 7   4/14/2021 at 10:37 (1,121 days old) by vacerator (Macomb, Michigan)   |   | |
really clean dishes well too! They cheapend the motors and pumps, and raised prices of course. |
Post# 1114857 , Reply# 8   4/17/2021 at 07:50 (1,118 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The KD10-14 machines had a 1/4 HP motor and the KD15-22 machines had a 1/2 HP motor.
Whirlpool did claim that the KD23 series had a 1/2 HP motor but it was the same size as the standard WP DW motor which was rated at 1/3 HP.
These large split phase motors were reliable but only about 30% efficient at best at converting power used to washing power.
Post# 1196806 , Reply# 9   1/9/2024 at 16:40 by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I believe that having a big motor equals power in every way, including spray and drain power. These are my thoughts. |
Post# 1196923 , Reply# 10   1/11/2024 at 11:43 by norgeway (mocksville n c )   |   | |
Worked ok, but were the all time noisiest dishwashers ever made.They sound like a garbage disposal fighting a chainsaw lol. |
Post# 1196936 , Reply# 11   1/11/2024 at 16:36 by Maytag85 (Sean A806)   |   | |
Post# 1197010 , Reply# 13   1/12/2024 at 22:22 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Steve, what model were portable dishwasher do you have? They made several different styles over the years.
I have two 35-year-old whirlpool built-in whirlpools in my kitchen. I do have concerns about some of the aspects of the new machines they do get dishes very clean, however. But I like the cycle times of the older ones in the fact that they will wash away so much food soil without ever ever having a filter to clean.
Post# 1197064 , Reply# 14   1/13/2024 at 20:28 by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1197757 , Reply# 15   1/23/2024 at 12:51 by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1197761 , Reply# 16   1/23/2024 at 13:24 by chetlaham (United States)   |   | |
That pictures wells up a lot of emotion in me, including deep sadness and longing. I wish that PowerClean was still being made today. No other dishwasher comes close in the history of humanity. If everyone was like me that dishwasher would be in every kitchen across the globe and the heater wouldn't cut off after the thermal hold... Sadly when the tall tubs were introduced people began buying them and it only increased. Whirlpool was clever, they had the point voyager which kind of mimicked the power clean to help get a certain number people on board with the idea- as if nothing was missing- then quietly switched to the filter design. All around messed up. I dislike how passive and naive people are.
Post# 1197762 , Reply# 17   1/23/2024 at 13:28 by qsd-dan (West)   |   | |
Smaller motors don't do more work, they just run 6 times longer to get the same job done. Instead of 20-30 minutes during the wash and rinse cycles, it's 1-2+ hours. Between weak designed motors to save electrical costs and reduced water levels to save water, dishwashers are quickly heading towards alternating wash arms as being the norm. Probably expect longer cycles times from them in the future.
Post# 1197771 , Reply# 18   1/23/2024 at 15:12 by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Have been alternating wash arms for over a decade now, this practice fix the dishwasher quieter, allows it to have less water that has to be heated in the machine, and generally does an excellent job
By any measure newer dishwashers today get things cleaner than the older machines ever could that’s the advantage of a long cycle. It will soak things off and then scrub them off that older dishwasher couldn’t touch, except on the very long and energy intensive pots and pans cycles that a few machines had. John |
Post# 1197852 , Reply# 19   1/24/2024 at 20:25 by norgeway (mocksville n c )   |   | |
Anything new is worth anything, But John is right, I have a 2 year old GE dishwasher and yes it takes a long time, but it cleans perfectly, burned on casseroles etc come out spotless. |
Post# 1197853 , Reply# 20   1/24/2024 at 20:45 by appnut (TX)   |   | |
Post# 1197858 , Reply# 21   1/24/2024 at 22:17 by qsd-dan (West)   |   | |
Yeah, I'm aware of longer cycles cleaning stubborn items. For years, I have posted pics my KDS-18 with an externally mounted switch to the timer motor that I can stall anywhere during the entire cycle. Thing is, stalling the timer just an extra 10 minutes or so during the wash cycle (pretty much doubling it) achieves the same results as hours on a newer dishwasher. It's extremely rare that I burn anything since I was never a fan of consuming hot foods or drinks.
BTW, the home I moved into almost 4 years ago came a Kitchenaid dishwasher from 2012 in the main kitchen. The KDS-18 resides in the kitchenette for occasional fun use now. It's quiet but sucks even with pots and pans with every single option selected. And that's on mechanically softened water. I make and eat a lot of homemade soups and it leaves residue all of the time, every time in my clear glass bowls. I never had that problem with 18 on very hard water and extremely short wash cycles before installing timer motor switch. I'm not worried about the residue as it's clean enough for me but I don't use those dishes when company is around. I'll take pics of my next load. My brother has virtually the identical dishwasher he bought brand new, just with top controls rather than front. I quickly understood why they rinse every dish under the kitchen faucet before putting it in the dishwasher. They get away with using the normal cycle using this method. Noticed when I mention alternating arms, I said it quickly becoming the norm, not something newly released. So John, when are swapping out your 80's Powerclean for a new dishwasher ;)
Post# 1197860 , Reply# 22   1/25/2024 at 00:02 by chetlaham (United States)   |   | |
Dan, you bring up a good observation. Higher water pressure (mechanical energy) in a vintage machine can in theory achieve the same results as a modern machine but requiring less time.
With cool water Powercleans did that. At 8 minutes into the Main wash they would do a thermal hold until the water was heated to 140*F which extended the main wash considerably. |
Post# 1197879 , Reply# 23   1/25/2024 at 11:33 by qsd-dan (West)   |   | |
Agree, it was a good balance of power, fast time cycles, and clean results. A couple of other designs had the right balance too but the reliability wasn't there (mainly in the electronics), like some of Maytags post RR dishwashers.
Most users today want a dead silent machine and it's just not happening with a 1/3 HP motor. The EPA wants the machine to use a trickle of water and electricity which throws more obstacles into the game. Manufactures today want to build the platform as cheap as possible and have it last just past the warranty and die soon after to boost profits. And here we are. |
