Thread Number: 87554
/ Tag: Vintage Dryers
DE606 "HOH" shut-off solenoid the book calls it |
Post# 1121182 , Reply# 1   6/23/2021 at 20:07 (1,037 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Matt, Why would you replace the shut-off solenoid if it Ohms out OK, In my nearly 50 year career of working on these dryers I have never seen a bad solenoid on one of these dryers, it only is activated for a spilt second once per load.
There are several other possibilities that often keep these dryers from shutting off properly.
Post# 1121193 , Reply# 2   6/23/2021 at 22:04 (1,037 days old) by qsd-dan (West)   |   | |
Post# 1121201 , Reply# 3   6/24/2021 at 00:09 (1,037 days old) by LowEfficiency (Iowa)   |   | |
Welcome to the forum, Matt.
It looks like you've done a significant amount of research and diagnosis already - far more than most who come here for help - so kudos for that. Is it correct to say that, absent the solenoid working, you've been shutting off the dryer by opening the door? The solenoid tug would only be brief... Is the linkage still in place that connects the solenoid to the tab on the back of the switch? And does that tab on the switch slide if you tug on it by hand (toward the solenoid)? If it does move, does moving it while the dryer is running cause the dryer to turn off? |
Post# 1121430 , Reply# 7   6/26/2021 at 01:42 (1,035 days old) by qsd-dan (West)   |   | |
Dryer temps should not exceed 160F, it sounds like the contacts in the cycling thermostat are shorted and the machine is running off of the high limit thermostat. The cooldown thermostat will shut off the motor after the solenoid engages, pulls the tab over on the switch, and temps drop down below 120F.
It wouldn't be a bad idea to verify wiring to the thermostats are correct. |
Post# 1121435 , Reply# 8   6/26/2021 at 06:09 (1,035 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1121448 , Reply# 9   6/26/2021 at 08:55 (1,035 days old) by hank_raster (Iowa City, IA)   |   | |
Post# 1121487 , Reply# 10   6/26/2021 at 19:42 (1,034 days old) by LowEfficiency (Iowa)   |   | |
>>Hi Matt, your 3rd picture in your reply #4 is likely the problem
Luckily the backside blew out instead of the front, so we can still read the part number. Looks like the C103B, a 200V SCR, this particular one manufactured by GE. They are obsolete, but some replacements are still available. Datasheet is on page 716 of this PDF: media.searchelec.com//specshee/G... |
Post# 1121491 , Reply# 11   6/26/2021 at 20:31 (1,034 days old) by qsd-dan (West)   |   | |
Post# 1121508 , Reply# 12   6/27/2021 at 06:51 (1,034 days old) by dnastrau (Lords Valley, PA)   |   | |
This supply house has them: CLICK HERE TO GO TO dnastrau's LINK |
