Thread Number: 87746
Whirlpool direct drive slipping into spin confusion |
Post# 1123212   7/13/2021 at 22:31 (1,017 days old) by maytaga806 (Howell, Michigan)   |   | |
Ever since I bought my DD last year it’s always slipped into spin. But what’s strange is that on the super wash 18 minute cycle, it doesn’t slip into spin and it operates as it should the whole cycle. Essentially for now we use that cycle the most so it doesn’t do that, but I’m wondering why this is. For example, If it agitates in the wash for anything less than 18 minutes it will slip into spin the first drain, so like the perm press delicate and soak cycle. Ive heard different things such as some components need to warm up first, or something like that.
I ordered a new coupler and I’m hoping this is the issue, but if it’s the coupler, why doesn’t it slip into spin every single time instead of only when it’s not agitated for long enough? Any input is very appreciated as always to help me figure this out because this is a machine I’m keeping forever. |
Post# 1123216 , Reply# 1   7/13/2021 at 22:53 (1,017 days old) by Yogitunes (New Jersey)   |   | |
the coupler does not control the neutral into spin sequence...
your neutral drain parts are failing....there is no rhyme or reason as to when it will work properly, or malfunction.... just the action of it not functioning as it should, is a clear sign, those parts should be replaced if you want it to function the way it was designed to.... in any case, there are plenty of vids on YT of how to open up the transmission and change out the parts..... not a bad time to clean out the trans and gears, add new fluid, and a new coupler would not be a bad idea at this point, I recommend the heavy duty one for extended life... for a few extra dollars, toss in a new pump and dogs for the agitator....and your machine should be set for many more years of service.... what the heck, inspect your fill and drain hoses for wear....replace if needed.... |
