Thread Number: 88351
Speed Queen water level question |
Post# 1129725 , Reply# 2   9/27/2021 at 09:34 (941 days old) by Yogitunes (New Jersey)   |   | |
well of course if you adjust to the raise the TOP level, the other levels are going to be affected as well....
but if you want to wash with a low water level, you could open the control panel and readjust the screw for each load, and then raise it again for full loads... the best way I found was to adjust the set screw for the highest level, and then used a dremel and trimmed the clover wheel for each level where I wanted....variables are a little tricky as you have to trim and file little indents back in... |
