Thread Number: 88361
/ Tag: Modern Dishwashers
Miele Dishwasher Advice |
Post# 1129257 , Reply# 2   9/21/2021 at 22:15 (947 days old) by PhilaTwin (Philadelphia)   |   | |
Thank you for the response, Nathan. Very helpful. How would I connect a valve to the severed blue hose inside the plastic tubing? A simple hose clamp? This model is a 120v, not sure if that matters. |
Post# 1129261 , Reply# 3   9/22/2021 at 00:28 (947 days old) by brisnat81 (Brisbane Australia)   |   | |
Hi Keith, thats right, just get a valve with the right size outlet on it, and use a hose clamp to hold it in place. Then just put spade connectors on the wire and connect those to the Inlet valve. |
Post# 1129706 , Reply# 7   9/26/2021 at 23:51 (942 days old) by appnut (TX)   |   | |
Post# 1129726 , Reply# 8   9/27/2021 at 09:36 (942 days old) by PhilaTwin (Philadelphia)   |   | |
Thanks, Bob. |
Post# 1129768 , Reply# 9   9/27/2021 at 16:21 (941 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Thanks for the info Nathan, I wasn't sure what was inside of the hose. Phila twin: Glad you have a working machine. Please share pictures of it. I Would like to know if it is similar to my first Miele DW inside. |
Post# 1130540 , Reply# 11   10/6/2021 at 15:30 (933 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Thanks for the pics, Keith. So the inside is identical to the G885 I had in 1996 except for that bolt. I don't recall any bolt sticking up from the bottom in the back. Does the dishwasher have a model number on it, perhaps on the door, or on a label on the right side of the door? |
Post# 1130574 , Reply# 12   10/6/2021 at 19:11 (932 days old) by PhilaTwin (Philadelphia)   |   | |
Looks like model # is G880 SCi. The other number is nr. 20/45209714. |
