Thread Number: 88484
Ge Filter Flo Clutch |
Post# 1130389 , Reply# 1   10/4/2021 at 19:11 (946 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1130391 , Reply# 2   10/4/2021 at 19:20 (946 days old) by Rodb (Wisconsin)   |   | |
That was a quick reply! Thank You so much. Make sense to replace the 30 yr old motor as well. |
Post# 1130400 , Reply# 3   10/4/2021 at 20:28 (946 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1130578 , Reply# 5   10/6/2021 at 20:53 (944 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Clutch to be heard |
Post# 1130629 , Reply# 6   10/7/2021 at 16:10 (943 days old) by Rodb (Wisconsin)   |   | |
Hope my transmission is ok. No oil on the clothes. Is that the only tell tale sign on the transmission going out? |
Post# 1130641 , Reply# 7   10/7/2021 at 18:10 (943 days old) by cfz2882 (Belle Fourche,SD)   |   | |
they will sling oil off the pulley once iron particals worn off of the spring clutch and other internal parts get between the oil seal lip and the input shaft. |
Post# 1130642 , Reply# 8   10/7/2021 at 18:12 (943 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1134859 , Reply# 11   11/29/2021 at 17:35 (890 days old) by Rodb (Wisconsin)   |   | |
Thanks for everyone's help. I found a new two speed clutch/motor assembly and a new water pump on e bay. Installed all and the old lady works like new again. I forgot how quiet it was when it newer! It just hums along while running. |
Post# 1134863 , Reply# 12   11/29/2021 at 20:35 (890 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1134872 , Reply# 13   11/30/2021 at 09:59 (889 days old) by rinso (Meridian Idaho)   |   | |
Rumor has it that since GE FF used two-speed clutches instead of 2-speed motors, if one resists using the delicate cycle too often, the clutch will last a lot longer. It's just what I read somewhere, my source could be wrong. |
Post# 1134878 , Reply# 14   11/30/2021 at 11:58 (889 days old) by Maytag85 (Sean A806)   |   | |
I have no idea why GE used 2 speed clutches instead of 2 speed motors but must have been a headache to deal with when it wasn’t working properly and was a bigger headache when oil leaked into the wash water and sometimes all the oil would leak into the wash water if the top of the transmission corroded through and the oil in the transmission (all 2 quarts of it) would spill out if the break assembly punched a hole in the side of the transmission.
Post# 1134881 , Reply# 15   11/30/2021 at 12:47 (889 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1134886 , Reply# 16   11/30/2021 at 13:46 (889 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I thought that changing the speed when the washer was running is what damages the clutch. Am I correct? |
Post# 1134896 , Reply# 17   11/30/2021 at 17:44 (889 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1134956 , Reply# 18   12/1/2021 at 11:42 (888 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It does not hurt either way, low to hi or high to low, if you switch high to low with the washer running it just will not shift down till the motor stops.
Reply #15 is correct, GE engineers wanted the pump always running at full speed for better pump out and filter flow and mini-basket performance.
