Thread Number: 89219
/ Tag: Modern Dishwashers
First Miele dishwasher software upgrade |
Post# 1138025   12/31/2021 at 23:34 (845 days old) by mielerod69 (Australia)   |   | |
Hi Everyone,
So just after 6 months of owning my G7919SCi dishwasher, the app sent me a notification of an upgrade. Quite a number of parameters have been upgraded. The main ones are: 1. PowerWash program has been optimised 2. 2nd Interim rinse setting 3. Dosage amount setting optimised Here are my observations: I have switched on the 2nd interim rinse. It adds 10 minutes to the program, but I have noticed a better result with shiner dishes and glassware. The dosage amount used to be adjustable between 5 grams to 10 grams. The default was 7 grams. I had set mine to 5 grams, now there are no longer grams showing instead, Normal, Increased, or Decreased. The Auto program starts with more water in the prewash, instead of 2 litres and adjusting for the load size, it is now 3 litres. There are no longer pauses between the cycle phases. The temperature on the ECO program is no longer shown in the display, this will certainly mean that the temperature of the program has been adjusted. I will report the changes when I run it. I haven't tried the PowerWash program yet but will report the changes. Overall, I'm pleased with the software upgrade. It amazing how they can tweet the programs to improve the overall performance of the machine. |
Post# 1138032 , Reply# 1   1/1/2022 at 03:21 (845 days old) by Logixx (Germany)   |   | |
Thanks for all these detailed posts about your dishwasher.
Pretty much the only reason I got my Siemens Zeolite is the Shine&Dry option that adds an extra rinse. The only alternative would have been Miele for twice the cost. I like how they provide details about the update - my Bosch dryer updated without any details (or noticable change). Maybe you can gain some insight about the cycle changes from current manuals. |
Post# 1138191 , Reply# 4   1/2/2022 at 17:07 (844 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Henene Does it pause between the prewash and wash and also between each rinse too? I guess the update put an end to that behavior. |
Post# 1138246 , Reply# 5   1/3/2022 at 04:49 (843 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
As far as I remember, yes, unless you select the express option. |
Post# 1138307 , Reply# 6   1/3/2022 at 17:57 (843 days old) by mielerod69 (Australia)   |   | |
I ran the ECO program the other day to see whether there was a change in the temperature and there wasn't any. The main wash is still at 55 degrees and the final rinse at 46 degrees. Miele has released a new model in Germany with an A rating for energy. That model has a 43 degree main wash and 42 degree final rinse. I ran a Gentle 45 program with Express option and the Main wash went to 55 degrees and the final rinse to a whopping 70 degrees. I must say I do like the 2nd interim rinse option which I will leave on.
@Logixx, I took screenshots of the update as it isn't stored on the app, that is the only downside. |
Post# 1138479 , Reply# 8   1/5/2022 at 09:36 (841 days old) by l86810 (Southend, UK)   |   | |
Awesome to see Miele not just pushing basic software updates to but introducing new functions too.
Sorry for kidnapping the thread... I've owned a Miele TCJ680WP Heat Pump dryer since 2018 and not had a single software update. When ever I have checked the app it just says it's up to date. Any one had any Tumble Dryer updates? |
Post# 1138500 , Reply# 9   1/5/2022 at 11:55 (841 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Rod can you give me the model number of the new machine released in Germany? |
Post# 1138518 , Reply# 12   1/5/2022 at 15:50 (841 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
My cooktop had a firmware update fresh out of the box, but my oven did not. Me thinks the dryers just don't have much to be updated. The only thing they majorly changed was adding the bedding cycle. All other cycles appear to be almost exactly the same across most version of the dryers. |
Post# 1138564 , Reply# 13   1/6/2022 at 02:38 (840 days old) by Logixx (Germany)   |   | |
