Thread Number: 89276
Safe electric intallation vs Bad electric installation. |
Post# 1138711 , Reply# 1   1/8/2022 at 06:55 (930 days old) by Fredriksam (Sweden)   |   | |
Next picture is perfect. Here they have a separate knob for ecah machine. One plus is that you can turn off the power completely to both machines which is good.
Post# 1138718 , Reply# 4   1/8/2022 at 09:23 (930 days old) by bradfordwhite (central U.S.)   |   | |
Electric outlets BELOW the plumbing connections...which do occasionally leak or over-flow.
Also not having the electric plug at a height that is readily available for someone to unplug the washer in an emergency. |
Post# 1138719 , Reply# 5   1/8/2022 at 09:24 (930 days old) by bradfordwhite (central U.S.)   |   | |
Not good. Just a constant drip from this wonderful install onto that plug strip would be cause for concern.
This post was last edited 01/08/2022 at 09:50 |
Post# 1138725 , Reply# 6   1/8/2022 at 10:05 (930 days old) by DADoES ![]() |
![]() Not my pics, found elsewhere. 1 = Apparent gas supply connected to the WATER inlet of a steam dryer. 2 = Dryer exhaust. 3 = Multiple dryers exhausted. |
Post# 1139305 , Reply# 7   1/14/2022 at 08:31 (924 days old) by Adam-aussie-vac ![]() |
Post# 1139338 , Reply# 9   1/14/2022 at 14:59 (924 days old) by bradfordwhite (central U.S.)   |   | |
