Thread Number: 89345
What Is Wrong With This Maytag VMW? |
Post# 1139493   1/16/2022 at 02:28 (922 days old) by chetlaham ![]() |
Saw this on Kirk's channel. I have to admit I'm a bit stumped as well. It appears that the tub is indexing on the second washer, motor is under extra load, but the splutch is not actuated into spin mode. Also, the problem seems to go away in diagnostic mode.
Can anyone diagnosis this or give a cause? |
Post# 1139515 , Reply# 1   1/16/2022 at 11:48 (922 days old) by Repairguy (Danbury, Texas)   |   | |
![]() 3
I’m not sure what they are thinking the problem is. Unless I missed something it looks like it’s working as designed. Motors can get pretty warm during operation and I’ve never had to replace a motor on any VMW machine. It doesn’t mean they don’t go out I’ve just never seen a bad one and I’ve worked on quite a few of these. I would definitely check the capacitor though as they get weak and that is a common repair on these. On the newer VMW machines they go though periods of slow and high agitation where the original ones did not do this. There is no tub brake so the wash basket does move with the agitation stroke.
Post# 1139538 , Reply# 3   1/16/2022 at 16:41 (922 days old) by murando531 ![]() |
![]() 3
You wouldn’t be able to stop the agitator by hand, trust me. Not without harming yourself. These VMW’s have incredible torque from their motor and planetary converter drive design, both the agitator and wash plate versions. If you could somehow hold the agitator still with a brace or something, I’m sure it would sheer the gears or slip/snap the belt before being able to oscillate the entire wash drum that rapidly.
I’m not sure either what’s supposed to be “wrong” in these videos. It looks and sounds to be operating just fine. The smoke was a big alarm at first until seeing in the comments that it’s from a cigar. Like, why would you not put that away while recording a video of something you’re supposed to be showing “malfunctioning”?? The tub gear *should* be spinning opposite of the main drive pulley, because the tub is what the planetary gear set is driving against. That’s why the entire outer tub assembly doesn’t violently yank back and forth, and is why it barely moved during the diagnostic cycle; the agitator has no clothes or water to work against. If there were a tub brake on these machines, the whole setup would twist like a GE plastic-fantastic from back in the day. |
Post# 1139568 , Reply# 5   1/17/2022 at 00:45 (921 days old) by chetlaham ![]() |
As already said, the agitator on the second machine can be stopped by hand, the motor is hotter than on the other machine (he touched both motors), and the tub appears to be indexing with the agitator rather than staying fairly stationary like in the first machine. Plus there is a slight sound difference.
