Thread Number: 89349
Honeycomb care and cat hair |
Post# 1139549 , Reply# 1   1/16/2022 at 18:47 (1,187 days old) by DADoES ![]() |
![]() 5
Post# 1139550 , Reply# 2   1/16/2022 at 19:03 (1,187 days old) by RP2813 ![]() |
![]() Our cat only sleeps indoors/on the bed when my buddy spends the night. She isn't allowed under the covers. We put a fitted sheet over the comforter to keep the cat hair off of it. This system works quite well.
When it's time to wash the fitted sheet, I use the Maytag 712 and will throw in some other items so I don't feel guilty about filling the tub at least half full so the lint filter will work. Once finished, I pull the lint filter out and find flat wads of cat hair on it, or sometimes they're stuck to the interior of the agitator and I peel them off.
I don't use my Neptune front loader for this sort of thing ever. I don't want to chance it with potential pump issues.
I would guess that your Frigidaire doesn't have a lint filter, otherwise I'd say to give it a try. Maybe if your dryer can be used as is on a no-heat setting after line drying, it will remove and trap the cat hair. |
Post# 1139554 , Reply# 3   1/16/2022 at 19:33 (1,187 days old) by qsd-dan (West)   |   | |
![]() You'll have to fix the dryer or get a top loader with a good filtration system.....meaning you'll have to go vintage. There isn't really another way around it.
The Pulsamatic doesn't have a filter so not much help there but a portion of the hair should float to the top and work its way into the outer tub and down the drain during the spin cycle. Hope you're not on a septic system or antiquated plumbing though. |
Post# 1139562 , Reply# 5   1/16/2022 at 22:48 (1,187 days old) by Launderess ![]() |
In general H-axis washing machines aren't best for lint/hair/bits removal. This has become more true as inner tub holes have become smaller to almost microscopic.
Tumble dryers are where lint, hair, etc... are removed best. That or various semi or fully automatic washing machines, especially those with lint filters. For top loading washing machines (with central beaters or impellers), twin tub (such as Hoover, etc..) or even wringer washers there are those Asian lint filters. See: www.amazon.com/Whaline-Wa... Use them in the Maytag wringer washer and they work a treat. Long ago learned never to put anything heavily or even moderately coated with hair or lint into the Miele or any other front loader, it just doesn't go well.. One reason have gone off using local laundromat is several local pet sitters, dog walkers/groomers and kennels bring doggie bedding and other items infested with hair. After using machine interior tub and glass is coated with hair. You can see more hair rising up from sump as machine fills if you're next person to use washer... |
Post# 1139565 , Reply# 6   1/17/2022 at 00:15 (1,187 days old) by askolover ![]() |
![]() That's one thing I'll give to the old GE FF washers. They worked wonders with pet hair! We had a long haired black cat back then. I wish I could have collected all the hair balls from that washer over its lifetime....I'd probably have a couple more cats made out of it.
I currently have four cats. Neither my Meile nor Asko does much for their hair. The GE and Frigidaire dryers do well catching it though. |
Post# 1139577 , Reply# 7   1/17/2022 at 05:08 (1,187 days old) by ozzie908 ![]() |
With the Honeycomb drum and your right its useless at animal hair removal, I have a throw on the sofa as the dogs lie against it and I have washed them in the Miele and end up with a huge ball of fur in the door seal, So have stopped using the Miele and use either Whirlpool FL or TL and then SQ gas dryer and no more pet hair is left on these throws. I guess as said above the holes are too fine and instead of ruining the drum get a 2nd machine for pet hair removal..!
Austin |
Post# 1139635 , Reply# 8   1/17/2022 at 16:36 (1,187 days old) by Rolls_rapide (.)   |   | |
![]() 3
The obvious answer: hoover the fabrics with a turbo-brush before you wash them. |
Post# 1139638 , Reply# 9   1/17/2022 at 16:57 (1,186 days old) by Launderess ![]() |
Post# 1139662 , Reply# 11   1/17/2022 at 19:20 (1,186 days old) by DADoES ![]() |
Post# 1139691 , Reply# 12   1/18/2022 at 03:50 (1,186 days old) by henene4 ![]() |
The newest SQ dryers have a pet hair removal cycle. As far as I understand, it's just a timed cool air cycle. You put the hairy items in the dryer first, wash them and then dry them. A 10-15min cold air only cycle in the dryer will reduce the amount of hair carried into the washer. |
Post# 1139692 , Reply# 13   1/18/2022 at 04:44 (1,186 days old) by askolover ![]() |
![]() 6
Post# 1139699 , Reply# 15   1/18/2022 at 06:28 (1,186 days old) by Launderess ![]() |
Tossing something into dryer set to "air fluff" or whatever no heat cycle would be fine I suppose. But using any sort of heat would likely contribute to baking soil (especially protein based in nature) onto fabric.
Why bother putting something dirty into dryer for lint removal? Assuming the thing is going to the wash just do so afterwards. |
Post# 1139708 , Reply# 16   1/18/2022 at 07:53 (1,186 days old) by henene4 ![]() |
Idea is that the hair won't spread onto other items or loads and that you don't have to clean everything out off the washer. |
Post# 1139713 , Reply# 17   1/18/2022 at 09:20 (1,186 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1139722 , Reply# 18   1/18/2022 at 12:11 (1,186 days old) by Unimatic1140 ![]() |
![]() 2
Overflow rinsing in your vintage Frigidaire Pulsamatic for three or four minutes should help greatly Chris. You'd fill the tub up and keep filling during the agitation to create the overflow rinse cycle, that's how the automatics do it. A lot of that pet hair will float over into the outer tub and down the drain. You could even to that as a "pre-wash" so to speak and then wash them in your Miele.
Post# 1139736 , Reply# 19   1/18/2022 at 14:32 (1,186 days old) by bradfordwhite (central U.S.)   |   | |
I agree with #8
Most laundering instructions from the manufacturers say to remove large items like coins in pockets, papers, etc. before laundering. Pet hair def. qualifies as a large item. Can't expect any washer or dryer to remove that. Using a mini power brush on one's vacuum is essential. I've on occasion used this to remove weed seeds, prickers, and other sticky seeds after going for a walk through the woods. I converted my Electrolux Sidekick to work with my central vacuum but any mini powered brush should work. I did my bathroom rugs this morning with it. |
Post# 1139753 , Reply# 20   1/18/2022 at 17:09 (1,185 days old) by gizmo ![]() |
![]() 2
Hi Robert Thanks, yes I was thinking of overflow rinsing in the Frigidaire - that's why I specifically mentioned that washer. It's in storage in the garage at our old house, where a relative now lives. It will need some TLC to get it back in action, that will happen soon.
Post# 1139758 , Reply# 22   1/18/2022 at 17:57 (1,185 days old) by Launderess ![]() |
"Idea is that the hair won't spread onto other items or loads.."
Well suppose that could work, but long held wash day wisdom states among other things sorting out what produces lint from what does not. Wouldn't dream of putting something full of pet hair or any other sort of fluff into a regular load as is so to speak. It is just a formulae for disaster. Using a clothes brush, lint roller, cello tape, vacuum or by whatever means major part of fluff/hair is removed from item before it goes into wash. This or offending item is laundered on its own by various means. Fluff, pet hair and other bits are where solid tub washing (by machine or hand in tubs) shines. Because one is lifting wash out of water (instead of latter draining through laundry) fluff, hair, and so forth become less of an issue. If doing wash by hand in tubs creating an "agitated overflow" rinse also works wonders. Have been doing this with black jersey pulls and other garments for some time now. |
Post# 1139759 , Reply# 23   1/18/2022 at 17:59 (1,185 days old) by bradfordwhite (central U.S.)   |   | |
![]() You have to make sure whatever clothing or soft items your vacuuming is attached at the corners so the suction won't suck it in. Opening the suction control takes some of that pressure off as well.
No, it is not the job of a washer/dryer to remove large gobs of lint or hair from clothing. The owners instructions specifically state that. A washer is intended to remove mainly liquid, or easily liquified soils such as body secretions, grubby dirt from daily activities, and food stains.
If your going to have a pet, you need to have the tools to care for them. An animal that is free roaming will require an appropriate vacuum cleaner with beater bar for carpeted areas and a mini turbo attachment for any surfaces that an animal is allowed to dwell on.
I stayed with a friend a while back that had one of those huge dogs that sheds profusely. Oh my lord. All the dog had to do was lay on a freshly vacuumed rug and the area would change to the color of the dog. It shed that much. One had to clean the beater bar on the vacuum after each use it would simply clog up that fast. Can't imagine the amount of pet dander and other bugs that would attract. Cats are just as bad. |
Post# 1139764 , Reply# 24   1/18/2022 at 18:56 (1,185 days old) by Rolls_rapide (.)   |   | |
I'm sure we've had this sort of conversation about pet hair, a couple of years ago. |
Post# 1139769 , Reply# 25   1/18/2022 at 20:17 (1,185 days old) by Launderess ![]() |
Don't know about all vintage top loading washers being great at fluff/pet hair removal.
One reason let our vintage WP convertible/portable washer go was that fed up with lint. Neutral drain did nothing for one either, and was that fed up with things (especially darker colored or blacks) coming out looking dreadful. Not even trip through dryer removed everything. Of course that washer only had the "Magic Mix" brush combo filter and dispenser. www.automaticwasher.org/c... Maybe other top loading automatics had better filtration systems. |
Post# 1139781 , Reply# 27   1/18/2022 at 21:36 (1,185 days old) by RP2813 ![]() |
![]() 2
![]() Chis, I have no idea what, or more specifically, who you were responding to.
That's not a complaint. It's an endorsement for the "hide" feature that makes viewing any posts made by chronically rude people a thing of the past. I highly recommend it for ensuring that any visit to AWO is a pleasant experience. |
Post# 1139783 , Reply# 29   1/18/2022 at 21:54 (1,185 days old) by bradfordwhite (central U.S.)   |   | |
You did state a vacuum that "...I scrounged from the dumpster behind a store, its fault was brush roll not turning..."
if that's the case how is it now "... a warranty return of a nearly new machine. It is as new." ? Maybe they do things different regarding returns in Ausie-land? ---- But I do appreciate, as I've done more than my share: "I have been rescuing/repairing appliances for over 30 years. When I have repaired an appliance, it works perfectly. It is also spotlessly clean." And it's always a good idea: "No repaired appliance is allowed in the house till I have dismantled it and cleaned it inside and out." ---- We're all just trying to help you with the lint/hair issue. |
Post# 1139788 , Reply# 31   1/19/2022 at 01:02 (1,185 days old) by Combo52 ![]() |
Far and away the best machines ever were the old combination washer dryers with a huge number of large holes they had in their cylinders. Other machines that we’re good we’re older front loader Westinghouse is with large holes in the baskets again.
My 15 year old Speed Queen frontload machine does a good job, but the two year old Speed Queen has fewer and smaller holes it’s not as good. Top load belt drive whirl pools were also very good at removing lint and hair. From clothing. The Miele machines with the honeycomb drums are ridiculous they don’t even get dirt out of the clothing like sand etc. The overflow rinsing in solid tubs is not particularly effective either,hair is heavier than water so it does not float out some of it is washed over but it’s not that effective. John L |
Post# 1139789 , Reply# 32   1/19/2022 at 01:21 (1,185 days old) by Launderess ![]() |
Simon the King of Clean recommends "Vamoosh Pet Hair Dissolver".
As with many other things reviews on Amazon are rather mixed. www.amazon.com/Vamoosh-Di... |
Post# 1139791 , Reply# 33   1/19/2022 at 05:44 (1,185 days old) by ozzie908 ![]() |
Post# 1139792 , Reply# 34   1/19/2022 at 05:45 (1,185 days old) by ozzie908 ![]() |
Post# 1139793 , Reply# 35   1/19/2022 at 05:48 (1,185 days old) by ozzie908 ![]() |
Post# 1139834 , Reply# 36   1/19/2022 at 19:36 (1,184 days old) by Unimatic1140 ![]() |
![]() 2
The solid tub GE Filter-Flo washers also are great at removing pet hair as it is recirculating over the top of the tub for the full wash and rinse cycle. When I've had items with heavy pet hair this machine got 99% in one washing.
The early machines AW6 machines with the self-cleaning filter rings also work the same way and get the majority of it out especially with the hair going down through the center of the agitator into the outer tub and back up to the filter screens. |
Post# 1139892 , Reply# 38   1/20/2022 at 16:57 (1,183 days old) by Combo52 ![]() |
Take a handful of pet hair take some lint while you’re at it put it in a quart jar shake it up and check it the next day 90% of it will be sitting in the bottom of the jar it is heavier than water.
Yes it does not sink quickly, and during agitation it stays pretty well in the water but it doesn’t naturally just go to the top and over and out. John L |
Post# 1139901 , Reply# 39   1/20/2022 at 18:12 (1,183 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1139911 , Reply# 40   1/20/2022 at 21:05 (1,183 days old) by Unimatic1140 ![]() |
![]() 2
I took this picture about 2002 when I washed our black lab Gladys' blanket that was full of her dog hair. It was washed in my first 1958 solid-tub GE Filter-Flo washer. I clearly remember not finding one hair left in that blanket lol! I didn't have an original copper pan at that time so I made one out of a 70's pan to fit that agitator.
Post# 1139936 , Reply# 41   1/21/2022 at 06:51 (1,183 days old) by Unimatic1140 ![]() |
![]() 3
Oh Chris I had another idea I just thought of to share with you. You could take your Pulsamatic and overfill it by about 2 gallons, the take the drain hose and put one of those drain hose filter screens on it and angle it over the tub and start it pulsating. This will cause a recirculation filtering system very similar to the GE picture I posted in the reply above this one.
You may not even need a filtering screen on the drain hose if there is a layer of suds in the outer tub. Suds also work well to capture hair and lint in the outer tub. I remember that worked quite well when I had designed that "Super Unimatic" which I incorporated a recirculation system into it. I have little doubt all of that pet hair will float over and be caught in the screen! ![]() |
