Thread Number: 89374
Kitcheanaide/Whirlpool Washer Making Grinding Noise |
Post# 1139861 , Reply# 1   1/20/2022 at 11:21 (918 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1139872 , Reply# 2   1/20/2022 at 12:14 (918 days old) by DADoES ![]() |
![]() Interesting that the noise occuring during spin doesn't begin until after the basket is accelerated to full speed. The agitate shaft disengages during neutral drain and spin but the rest of the internal gears continue to oscillate with the same motions. May be a problem with the cam on the agitate shaft. |
Post# 1139882 , Reply# 3   1/20/2022 at 14:26 (918 days old) by hemjs01 (Glenview)   |   | |
When you say pump? I would assume you mean the white water pump attached to the motor. I did clean it out and it appears to be working because the water in the tub is draining properly. |
Post# 1139894 , Reply# 4   1/20/2022 at 17:09 (918 days old) by Combo52 ![]() |
Post# 1139908 , Reply# 5   1/20/2022 at 20:35 (917 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1139914 , Reply# 6   1/20/2022 at 21:41 (917 days old) by DADoES ![]() |
![]() 2
Post# 1140003 , Reply# 8   1/21/2022 at 17:42 (917 days old) by DADoES ![]() |
![]() 2
![]() Not if you want to have a better machine than anything new, other than perhaps Speed Queen. A few (not all) of the transmission internal parts are available, depending on what's causing the problem ... if you feel up to opening it up for examination and possible repair. Corecentric (a rebuilder) is offering refurbished transmissions on Amazon for $126 plus sales tax, free shipping. A couple other sources are $144 and $151, both plus shipping and tax so that does put it upwards toward $200. |
