Thread Number: 89441
/ Tag: Vintage Dishwashers
Please help identify dishwasher model so I may fix it! |
Post# 1140441 , Reply# 1   1/26/2022 at 19:14 (820 days old) by appnut (TX)   |   | |
Post# 1140442 , Reply# 2   1/26/2022 at 20:21 (820 days old) by Jazzgrrl (Edmonton Alberta)   |   | |
Thank you for your reply! I was thinking it would be earlier as I believe it may be original to the house, which is 1959, but perhaps it was a later addition? |
Post# 1140457 , Reply# 3   1/27/2022 at 01:11 (819 days old) by petek (Ontari ari ari O )   |   | |
Post# 1140458 , Reply# 4   1/27/2022 at 02:54 (819 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 1140474 , Reply# 5   1/27/2022 at 09:41 (819 days old) by Jazzgrrl (Edmonton Alberta)   |   | |
Thanks, it’s definitely from underneath. I took off the kick plate and it seems to be right under where the sump seal is, hence trying to figure out the model so I may try to source the part. |
Post# 1140478 , Reply# 6   1/27/2022 at 10:36 (819 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Tara, it is likely either leaking from the pump shaft seal or the sump gasket where the whole pump and motor assembly fits into the DW tank.
If it is the sump gasket you can probably reseal it with a good marine sealant, if it is a shaft seal you have to disassemble the pump and rebuild it [ good luck ] getting it apart and finding parts.
It is not real likely you will get much more use out of this DW without problems, these were not durable machines even when new.
Post# 1140480 , Reply# 7   1/27/2022 at 10:47 (819 days old) by petek (Ontari ari ari O )   |   | |
Post# 1140481 , Reply# 8   1/27/2022 at 10:48 (819 days old) by appnut (TX)   |   | |
Post# 1140620 , Reply# 10   1/29/2022 at 07:15 (817 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
