Thread Number: 89469
/ Tag: Modern Dishwashers
LG Dishwasher Question |
Post# 1140734 , Reply# 1   1/30/2022 at 20:31 (1,139 days old) by nmassman44 ![]() |
I have an LG dishwasher as well and I do use the Turbo Cycle only to wash my cats water fountain thru when I need it fast. Turbo cycle ramps the power of the wash pump to the max and does use more water per fill. The dishwasher is much louder in this cycle in my opinion. I dont use it for large everyday loads and stuff that has baked on stuff but it will do the job.It also does not have a dry portion of the cycle but it will run the fan at the end of the cycle. Hard dishwasher tabs like Finish wont have enough time to dissolve in the wash portion of the cycle so powdered detergent should be used.
You could be adventurous and try it and see what you think. Also pressing the High Temp water temp will extend the cycle a bit. My LG dishwasher is LDF5678....also I rarely if ever use Auto since I find that it does take longer...most of the time I use Normal or Heavy and with the High Temp option added. Both cycles will use the Sensor system and add or subtract rinses as needed. |
Post# 1142572 , Reply# 5   2/19/2022 at 08:53 (1,119 days old) by DADoES ![]() |
![]() 2
