Thread Number: 89488
Blomberg Appliances |
Post# 1140888   2/1/2022 at 12:18 (906 days old) by Kenmore58 ![]() |
A co-worker is thinking of purchasing a Blomberg washer and dryer to replace her Kenmore stack unit which has developed problems. I tried to repair the washer for her, but it would involve replacing the motor, which may or may not fix the problem.
Has anyone had any experience with Blomberg Appliances? My limited research shows they are from Germany and are available here in the U.S. Any thoughts or suggestions would be appreciated. RON |
Post# 1140891 , Reply# 1   2/1/2022 at 12:39 (906 days old) by donprohel ![]() |
![]() 2
Other members will provide much better information, but just to start Blomberg is a brand of Beko, which is a Turkish manufacturer of low-end appliances |
Post# 1140893 , Reply# 2   2/1/2022 at 13:01 (906 days old) by KENMORE58 ![]() |
Post# 1140896 , Reply# 3   2/1/2022 at 13:37 (906 days old) by coldspot66 ![]() |
![]() 2
Hi Ron, Kenmore stack....is it Frigidaire made or Whirlpool made? What is the problem? Hope you are well. Also, 2 units stacked, or one unit? John |
Post# 1140897 , Reply# 4   2/1/2022 at 14:06 (906 days old) by Kenmore58 ![]() |
Hey, John!
Great to hear from you. This is the unit that, several years ago, I asked your opinion on what to get to replace her stack front load machines. It is a Kenmore top load machine with attached dryer on top. She decided to wash bed pillows in it. Now is goes off balance right away when it starts to spin. My diagnosis was that she put such a strain on the motor that she damaged it and now it can't ramp up fast enough and therefore the load remains unbalanced. Her husband asked about replacing the motor. I told him that this is not a definitive diagnosis about the motor, but he could try it. In the meantime, they bought a new stack set. When the appliance store got there, they decided that it was too tight a space to try to get the old one out and get the new one in. So they left, with the new machine. She's now looking into a stack set by Bosch. I think it's going to have to be two separate units and then assembled in the laundry room because of the tight fit getting the machines in. Life is okay here in Rhode Island. Come on down sometime when you have time and we can rebuild a washer or two. Hope all is good with you. RON |
Post# 1140902 , Reply# 5   2/1/2022 at 15:57 (906 days old) by coldspot66 ![]() |
![]() 2
Hi Ron, Has anyone taken off the front panel to see if one of the suspension springs let go. Does the tub center in the opening when not running? Frigidaire stack units have pretty beefy suspension. John |
Post# 1140949 , Reply# 6   2/1/2022 at 21:09 (906 days old) by quincyman (Oldsmar, FL)   |   | |
Never even heard of the brand of washers. Do you have any pictures to share? |
Post# 1140950 , Reply# 7   2/1/2022 at 21:56 (906 days old) by foraloysius ![]() |
Post# 1140953 , Reply# 8   2/1/2022 at 22:19 (906 days old) by mielerod69 (Australia)   |   | |
Post# 1140954 , Reply# 9   2/1/2022 at 22:35 (906 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1140957 , Reply# 10   2/2/2022 at 01:11 (905 days old) by askolover ![]() |
Post# 1140974 , Reply# 11   2/2/2022 at 08:30 (905 days old) by Kenmore58 ![]() |
Post# 1140991 , Reply# 12   2/2/2022 at 11:46 (905 days old) by coldspot66 ![]() |
Does it agitate ok? Check the belt and idler pulley. Does it try to spin at all, or just hum? |
Post# 1141020 , Reply# 13   2/2/2022 at 16:22 (905 days old) by Kenmore58 ![]() |
![]() 2
Post# 1141022 , Reply# 14   2/2/2022 at 16:26 (905 days old) by appnut ![]() |
![]() 2
Post# 1141150 , Reply# 15   2/4/2022 at 06:38 (903 days old) by askolover ![]() |
