Thread Number: 89632
Kenmore 110-28102 ate the shaft bearing yet again BUT... |
Post# 1142242 , Reply# 1   2/15/2022 at 06:47 (892 days old) by combo52 ![]() |
![]() 3
Have you installed a new strut kit in this washer, the struts get weak and the thing can’t spin properly.
Definitely get an OEM kit if you’re going to do this it’s easy to do it may solve your problem. Best long-term washing machines are frontload machines very best frontload you can get is a Speed Queen easy to work on and will last a long time. The day of top loading washing machines is over. Unless you’re willing to put up with high water use and high utility costs detergent etc. John L |
Post# 1142250 , Reply# 2   2/15/2022 at 07:17 (892 days old) by DADoES ![]() |
![]() 2
![]() I've always been curious about those short-life bearings on WP machines of that ilk. The five F&P toploaders that my family has had in use ranging from 13 to 22 years all have the original bearings. Dartman, bad suspension rods are a cause of off-balance issues as John says. I have changed them on both of my F&P HE/impeller models. |
Post# 1142328 , Reply# 4   2/15/2022 at 23:29 (891 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
