Thread Number: 89658
Difference Between Speed Queen Classic Heavy Duty & Bulky/Sheet Cycles |
Post# 1142605 , Reply# 1   2/19/2022 at 16:05 (888 days old) by appnut (TX)   |   | |
Post# 1142771 , Reply# 2   2/22/2022 at 01:45 (885 days old) by Grebus (Edmonds, WA)   |   | |
I created a corrected cycle matrix for the TC5 that you might find useful, here is the link: CLICK HERE TO GO TO Grebus's LINK |
Post# 1143219 , Reply# 4   2/26/2022 at 16:02 (881 days old) by DADoES (TX, U.S. of A.)   |   | |
The TC5/Classic does not have auto sensing for the load size or fill level. Fills are hard-coded at two levels, per the chosen cycle and whether or not the Deep Fill option is selected. The cycle matrix chart references the fill levels by gallons and inches of depth. The figures are for each fill, not the entire cycle, so double it for a filled/agitated rinse and add a bit for spin-spray rinses. Normal Eco -- 9in/13gals or 11in/16gals (runs only a spin-spray rinse unless Extra Rinse option is selected) Heavy Duty, Perm Press, and Delicate -- 10in/14.5gals or 13in/19gals Bulky/Sheets -- 11in/16gals or 13in/19gals The least amount of water possible (for a small load or single item) is 13 gals + the spin sprays, on Normal Eco cycle with no extra rinse or Deep fill option selected.
Post# 1143344 , Reply# 5   2/27/2022 at 20:08 (880 days old) by Suebee (Chelsea, MI)   |   | |
Thanks so much for your helpful reply. |
