Thread Number: 89724
/ Tag: Modern Dryers
Is this normal for auto dry? |
Post# 1143303   2/27/2022 at 12:00 (788 days old) by chetlaham (United States)   |   | |
Post# 1143304 , Reply# 1   2/27/2022 at 12:13 (788 days old) by chetlaham (United States)   |   | |
Post# 1143305 , Reply# 2   2/27/2022 at 12:24 (788 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1143307 , Reply# 3   2/27/2022 at 12:58 (788 days old) by chetlaham (United States)   |   | |
Even down to second and sub second periods?
I always thought (assumed) the board had a restrain/timer; in that the dryness pads would have to sense reduced moisture for X amount of minutes before letting the timer run, and then X amount of minutes of moisture before re-activating the timer to prevent short cycling the timer. But I guess I just learned something new! :) |
Post# 1143312 , Reply# 4   2/27/2022 at 13:32 (788 days old) by DADoES (TX, U.S. of A.)   |   | |
Maybe there is some logic involved but your description of the timer's action seems not. Perhaps someone will come along and clarify. Either way, a mechanical timer must physically run-out the time on the heating cam to cool down and off vs. an electronic control that is fully digital on detecting/counting and reacting to moisture hits. |
Post# 1143336 , Reply# 5   2/27/2022 at 19:11 (787 days old) by chetlaham (United States)   |   | |
Post# 1143355 , Reply# 6   2/27/2022 at 21:16 (787 days old) by Dustin92 (Jackson, MI)   |   | |
I have a gas Whirlpool that sounds exactly as you describe.. A rapid clicking and clunking sound. It's slightly annoying but working as designed. |
Post# 1143356 , Reply# 7   2/27/2022 at 21:23 (787 days old) by chetlaham (United States)   |   | |
Yup, thats the sound! I rarely use sensor dry, but when I did yesterday and heard it for the first time I became alarmed thinking the dryness control board was malfunctioning. Its comforting to know this is indeed normal. And will not over heat the timer motor.
I will give Whirlpool credit for their sensor dry system, it is IMO one of the best on the market and does the job well. |
