Thread Number: 89727
/ Tag: Modern Dishwashers
Whirlpool dishwasher heating issue |
Post# 1143439 , Reply# 4   2/28/2022 at 20:53 (879 days old) by combo52 ![]() |
Post# 1143446 , Reply# 6   2/28/2022 at 21:57 (879 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1143459 , Reply# 8   3/1/2022 at 05:52 (878 days old) by combo52 ![]() |
And order the correct one from whirlpool,
Elements in older dishwashers did glow red hot if it’s getting orange that’s even hotter than red hot , did you try putting an amp meter on it? When the element is not wet it should be drawling only two or 3 A I think yours is probably drawling about eight or 10, you may ruin the control board using this element as well. John L |
Post# 1143468 , Reply# 9   3/1/2022 at 07:26 (878 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1143502 , Reply# 10   3/1/2022 at 15:37 (878 days old) by GELaundry4ever ![]() |
Did you try normal cycle with heat dry? What about rinse aid? Either try that, or sensor, high temp and heat dry. |
