Thread Number: 89728  /  Tag: Modern Automatic Washers
new maytag washer MVW6230HW
Post# 1143351   2/27/2022 at 20:50 (1,145 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
a few things i notice since using this washer as daily driver
1 efficent and effective wash on deep water wash (max fill)
2 when set on hot water even when mixing hot and cold when switching to hot water during fill and mixing during sensing of load hot water is stronger than cold and i also notice quick wash for small loads is good but when loads are bigger i use the heavy duty cycle max fill wash time is 2:19 but worth it as it alows stain elimination on shirts and since knowing the site i have use hot and warm water wash more than cold only use cold water when needed or depending on item other wise its set to warm or hot and for that i again say thank you to all aw members for teaching me that
Post# 1143397 , Reply# 1   2/28/2022 at 13:06 (1,144 days old) by GELaundry4ever (Nacogdoches, TX, USA (considering moving to Temple, Texas))
Normal cycle with softener option
Have you tried the default normal cycle with softener option added?
Post# 1143429 , Reply# 2   2/28/2022 at 19:40 (1,144 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
i did its more like an normal eco cycle with a spray rinse before the final rinse and max fill can not be chosen and i always have the softner option on
Post# 1143447 , Reply# 3   2/28/2022 at 21:58 (1,144 days old) by GELaundry4ever (Nacogdoches, TX, USA (considering moving to Temple, Texas))
normal wash with softener
I thought the normal cycle with softener on did a deep rinse. What am I missing?
Post# 1143467 , Reply# 4   3/1/2022 at 06:42 (1,143 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
it do but before the deep rinse it do 5 spray rinse to have the deep rinse need to activate the extra rinse option manuel is just a quick guide for this model so no cycle chart for wash time and rinse
