Thread Number: 89732
/ Tag: Vintage Dishwashers
Caloric DUS104-19 Issues |
Post# 1143413 , Reply# 1   2/28/2022 at 15:37 (787 days old) by turquoisedude (.)   |   | |
I'd say it sounds more like the water inlet valve - if you hear the machine start up right away, that's the wash/drain pump. Is it possible that the water supply pipe to the dishwasher was altered or shut off because of the bathroom remodel? Don't laugh, but I lived in a house where the hot water line to the bathroom had been tapped into in order to connect a dishwasher - when the hot line got shut off to the bathroom, the water to the dishwasher was also shut off! |
Post# 1143421 , Reply# 2   2/28/2022 at 17:42 (787 days old) by Stainfighter (Columbia, SC)   |   | |
Post# 1143422 , Reply# 3   2/28/2022 at 17:51 (787 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1143430 , Reply# 4   2/28/2022 at 19:41 (787 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 1143441 , Reply# 5   2/28/2022 at 21:18 (787 days old) by quincyman (Oldsmar, FL)   |   | |
Wonder who or what D & M is/was. |
Post# 1143443 , Reply# 6   2/28/2022 at 21:23 (787 days old) by DADoES (TX, U.S. of A.)   |   | |
Design & Manufacturing ... produced dishwashers labeled for numerous brands. CLICK HERE TO GO TO DADoES's LINK |
Post# 1143462 , Reply# 9   3/1/2022 at 06:08 (786 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
When you start the dishwasher are you hearing the humming sound of the valve just to be sure make sure nothings underneath the float holding it up in the bottom of the tank.
It does sound like you have a valve problem just the shock of turning on and off the water to an old inlet valve in a DM dishwasher could be enough to ruin it so you may need a new inlet valve at this point don’t try to fix the old valve or clean it unless you have a good flood insurance. Install a new valve, if you can’t get one for a DNM dishwasher you can use a KitchenAid valve 4171000 will fit Hi Charlie you gave me the laugh at the day when you said there’s old D&M dishwashers were well-made. John L |
Post# 1143471 , Reply# 10   3/1/2022 at 08:10 (786 days old) by quincyman (Oldsmar, FL)   |   | |
Never really knew that. |
Post# 1143475 , Reply# 11   3/1/2022 at 11:23 (786 days old) by neptunebob (Pittsburgh, PA)   |   | |
Most Kenmore dishwashers were made by D&M until about the mid 80s, usually they did not last long and that is why Sears sold so many dishwashers. Then they started to source some machines from Whirlpool and they were much better. Most D&M dishwashers have long been recycled/to the landfill long ago. |
