Thread Number: 90030  /  Tag: Modern Automatic Washers
Speed Queen Front Load Water Level
Post# 1146185   4/10/2022 at 10:08 (1,080 days old) by IIIJohnnyMacIII (North Carolina)
iiijohnnymaciii's profile picture
How does the FF7 know how much water to put in the machine? Does it have a sensor or is it based on manual selection? Thanks!
Post# 1146187 , Reply# 1   4/10/2022 at 10:50 (1,080 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
launderess's profile picture
Likely via sensors including feedback from a pressure switch.
Few if any domestic front loaders have user adjustable water levels. Amounts used usually vary by cycle (normal, permanent press, woolens, delicates, etc...). For normal cottons/linens wash water levels are low and rinses high.
docs.alliancelaundry.com/tech_pd...
Post# 1146189 , Reply# 2   4/10/2022 at 11:29 (1,080 days old) by NeptuneGuy27 (Baltimore,MD)
My SQ FF7
My Speed Queen FL will fill the entire bottom of the tub to just an inch or so below the tub opening on all cycle except "Sanitize with Oxi". That cycle fills up to the bottom of the door for the Soak (if added), PreWash (if added), and Main Wash portions; rinses are at the normal level. I tried to get a picture for you but it might be a little hard to see with the water beaded up on the door.
Post# 1147637 , Reply# 3   4/28/2022 at 14:27 (1,062 days old) by Cavimum (USA)
We have the SQ FF7. I have no idea how many gallons a fill is, but my personal observation since acquiring it four months ago is that the water level never gets above the gasket level, no matter which cycle is selected, and I've tried all the cycles, in the name of research. LOL
HTH
Post# 1147659 , Reply# 4   4/28/2022 at 23:58 (1,061 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
New sq fl water level
combo52's profile picture
This is correct level should never get above door seal.
John
