Thread Number: 90031
/ Tag: Vintage Dishwashers
Potscrubber Water Supply |
Post# 1146205   4/10/2022 at 14:08 (746 days old) by Cam2s (Nebraska)   |   | |
When did GE transition the Potscrubbers to use 120 degree water? Also did they ever offer them with a thermostatically held main wash? Also did they put a more powerful heater in them? |
Post# 1146221 , Reply# 1   4/10/2022 at 16:56 (746 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1147498 , Reply# 3   4/27/2022 at 06:29 (729 days old) by Chetlaham (United States)   |   | |
Was around 1983 IIRC.
BOL plastisol and BOL Hotpoints up until early 1980s had only about a 10-15 minute heated main wash, which was then extended to a 20-30 minute main wash in 1983. MOL models prior to 1983 had a "Potscrubber" feature which extended the heated main wash by about 15-20 minutes enough to give good heating and wash results at 120*F IMO despite the manual calling for 140*F. Some TOL models prior to 1983 also had a thermostat that would hold the timer during the main wash until the thermostat was satisfied. In 1983 all BOL models came with a 30 minute heated main wash, and all MOL and TOL came with with a thermostat and cycle extender that could extend the main wash past 15 minutes if needed. Around the mid 90s GE began dropping all the thermostats and cycle extenders for fixed 30-56 minute main washes regardless of the cycle selected or inlet temperature. For example, when I had a new GE DW installed in 2011, the heated main wash was 47 minutes long for all cycles, despite the machine only having a 1.2 gallon water charge in the main wash. 120*F made for some hot water, and 150*F inlet easily got it near boiling. I can confirm this is indeed the key to scrubbing pots. Today sadly the heater in most dishwasher cutouts as soon 105-140*F is reached. So, no new machine today is capable of scrubbing pots :( |
Post# 1147499 , Reply# 4   4/27/2022 at 06:37 (729 days old) by Chetlaham (United States)   |   | |
Sorry for the blur, here is a better version. Thats 45 minutes of 500 watts against 1.2 gallons of water <3
imgur.com/a/6UjePQt... No dishwasher on the market was ever cable of producing hotter water than a post 1983 GE dishwasher. Imagine a Whirlpool power clean, Maytag or Hobart that could take 140-150*F inlet and boost it to a steady 195*F. So many machines lacked real water heating. |
Post# 1147500 , Reply# 5   4/27/2022 at 06:39 (729 days old) by Chetlaham (United States)   |   | |
Post# 1147652 , Reply# 6   4/28/2022 at 20:58 (728 days old) by appnut (TX)   |   | |
