Thread Number: 90239
Miele w4842 vs Miele w1-860 |
Post# 1148099 , Reply# 1   5/5/2022 at 22:05 (1,078 days old) by Launderess ![]() |
Rated capacity on Miele W4XXX series is somewhat deceiving.
For Normal/Cottons/Linens Miele recommended not loading washer more than 3/4 full. Meanwhile on W3XXX series one could load as usual for a Miele front loader of time, full leaving about a closed fist worth of room at top of load. Others will chime in as to if newer Miele washers still can handle full loads as above. If you have a cleaning business I'd suggest looking for a SQ front loader either maybe used at good price, or perhaps new (same). Cycle times will be faster as SQ are no nonsense but robust machines. Since you're using washer for business purposes you can expense cost on your taxes. Much as one loves one's European front loaders, there are times when don't want nor need > one and one half hours for a load of wash. Nor need things to be mollycoddled, but could do with washer that can handle 18lbs of wash and or bulky things quickly and efficiently. |
