Thread Number: 90285
Speed Queen TC5 Tub Lean |
Post# 1148579   5/12/2022 at 17:54 (806 days old) by BlockEight88 ![]() |
Good day,
I have a 2 year old Speed Queen TC5000WN washer. I will try and get straight to the point. I like to switch between this and a Kenmore 80 Direct Drive. I am not sure by doing so if I have messed up the springs in the TC5. I have thoroughly researched the tub leaning and from my research, have gathered this is "normal operation". My issue seems to be more prevalent than others. My flooring was recently re done and since I have reinstalled the TC5, I cannot get the tub to excessively stop leaning. The machine appears to be level front and back, side to side (maybe off very slightly, but still within the level lines). After about a dozen times re-leveling the machine, I feel I may have made matters worse. The tub is now leaning to the right rear (opposite direction of the motor torque). I have tried to add some foam to the front right spring to secure it in place, but that doesn't appear to be working. I understand that all SQ washers will lean to some degree, but how do I get mine to lean at least forward with a little pull on the side? I have read on these forums the best solution is to add some foam to secure the springs to help with the torque. Perhaps someone can share a photo of how they have tweaked the interior with foam because I’m stumped and don’t want to make matters worse? Here is a link to my video demonstrating the issue. ?t=511 Any insight is greatly appreciated. |
Post# 1148580 , Reply# 1   5/12/2022 at 18:00 (806 days old) by BlockEight88 ![]() |
Here is a photo of the inside. Sorry, forgot to add before.
Post# 1148666 , Reply# 2   5/13/2022 at 20:54 (805 days old) by BlockEight88 ![]() |
Post# 1148671 , Reply# 4   5/13/2022 at 22:03 (805 days old) by qsd-dan (West)   |   | |
Post# 1148682 , Reply# 7   5/14/2022 at 06:35 (804 days old) by BlockEight88 ![]() |
I really appreciate all the input. Maybe I’ll just leave it alone. I removed all the foam this morning and here is what it does. I guess compared to some, this isn’t that bad.
Inspection the springs, they seem fine. I think a little play is normal.
Post# 1148697 , Reply# 9   5/14/2022 at 09:13 (804 days old) by BlockEight88 ![]() |
Post# 1148762 , Reply# 11   5/15/2022 at 13:58 (803 days old) by BlockEight88 ![]() |
Seems better after putting some foam around the tub on the back and right front side. Not sure if this is a long-term solution though.
