Thread Number: 90336
speed queen front load door seal? |
Post# 1149035 , Reply# 2   5/19/2022 at 07:17 (799 days old) by ozzie908 ![]() |
It may be tight but if its left closed for long periods it can easily warp a new seal may stop the drip but before you go buying. a new one try a green scotchbrite pad with cream cleaner and give the glass a good scrub sometimes its a little bit of limescale you cannot feel or see that is allowing a drip out of the door. Its worth a shot.
Post# 1149087 , Reply# 3   5/19/2022 at 18:42 (799 days old) by kenc (SF Bay Area)   |   | |
Thanks, I have gone around looking for calcium and treating with CLR where I see it. On the SQ, it's a plastic ring around the door glass that bears on the seal, but I get your message and will give it a go. |
Post# 1149253 , Reply# 5   5/21/2022 at 20:53 (797 days old) by kenc (SF Bay Area)   |   | |
![]() 4
I hope I'm not jinxing it, but after several thorough cleanings of the glass and the rubber seal with CLR (a limescale remover), we've now done two loads with no leaks. Thanks for the advice both of you. |
Post# 1157398 , Reply# 7   8/19/2022 at 21:32 (706 days old) by combo52 ![]() |
![]() Nice looking W&D Pete.
I got my SS SQ FL machine almost 2 years ago, no problems what so ever. Alco bought a SS one for my partner and no problems wit his either.
A few years ago we had one of these at a beauty shop that leaked a little and we changed the boot under warranty which solved the problem.
Try the suggestions above and if it keeps happing either call for warranty service or call SQ if you like doing things yourself and have them send you the part.
SQ has by far the easiest to change door boot in the industry it only takes a few minutes to change. On most brands you might as well throw the machine away when the boot needs changing, Frigidaire-electrolux is about the worst one, but WP-MT is not much better.
Post# 1158015 , Reply# 9   8/27/2022 at 13:35 (699 days old) by biggpete ![]() |
Hey Ken, Just of of curiosity, has the door boot seal to your Speed Queen front load washer still totally quit leaking? Pete |
Post# 1158019 , Reply# 10   8/27/2022 at 14:39 (699 days old) by stopmeister72 ![]() |
I have a drip every once is awhile as well. Seems the door is out of kilter a little, not sure why. I can push the bottom frame of the door in about 1/4 of an inch but the top is fine. And that makes a difference on the amount of contact of the seal on the bottom. Have also used some bar keepers friend to scrub the glass to get the buildup off.
