Thread Number: 90687
Recommendations please--FL stackable W/D Full Size |
Post# 1151909   6/21/2022 at 11:40 (766 days old) by sarahperdue (Alabama)   |   | |
Hi Y'all,
I'm looking for recommendations for full sized front loading washer and dryer that can be stacked. I would like: All mechanical Enough water usage that I don't see my laundry sloshing around in three inches of grey sludge Long life Low maintenance (I don't want something so vintage that I have to learn how to repair them) Used is fine Will travel for good units (John L.) I don't know if all of these attributes are available. I don't know much about front loaders or newer machines. I have a pair of 1990s semi-commercial Speed Queens at home. I also have the fabulous vintage calico (harvest gold and avocado--she will grow up to be white) GE Combo that John created for me. Thanks, Sarah |
Post# 1151911 , Reply# 1   6/21/2022 at 11:51 (766 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1151916 , Reply# 2   6/21/2022 at 13:11 (766 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
unless going full vintage like frontload westing house or those old school mechanicaltimers frigedaire front load unless buying used refurbish that you can restore repair yourself those would be your only option something like in this pic to be precise pretty sure dadoes woulld agree with my post
Post# 1151918 , Reply# 3   6/21/2022 at 13:33 (766 days old) by sarahperdue (Alabama)   |   | |
there are no new machines mechanical controls, but one can hope.
Does anyone know of a somewhat recent machine that might fit the bill? The last new machine I bought was an all mechanical TL in 2005. It was a Whirlpool. I loved it. Alas, my younger son, three at the time, was collecting lamp bead chains he called his snakes. He left one in his pocket. I missed it when I did the laundry, it wrapped itself around the transmission and killed the washer dead. But, I digress. Sarah |
Post# 1151922 , Reply# 4   6/21/2022 at 14:47 (766 days old) by ryner1988 (Indianapolis)   |   | |
Perhaps I'm missing something, but I've honestly never heard of front loaders with mechanical controls. I'm sure they exist, given that front loaders have been around way longer than electronics have. I've just never seen one.
Is it possible that you could find a used Whirlpool like the one you mentioned? They're still floating around out there since a lot of people are re-conditioning older machines. There's a bigger push than ever before to keep old machines going longer because there's a sizable chunk of the population unimpressed with today's offerings. So I'm sure you could find something similar to your 2005 Whirlpool if you look hard and long enough. Ryne |
Post# 1151936 , Reply# 5   6/21/2022 at 18:54 (766 days old) by whatsername (Denver, CO)   |   | |
There are only two "recent" models that come to mind; both are quite long in the tooth and probably belong in the imperial forum. The "FriGEmore", available as stackable units or less commonly as a unitized laundry center, and the Maytag Neptune super stack. I see the FriGEmore units all the time on craigslist. The Maytags not so much.
Some pics from around the web: |
Post# 1151942 , Reply# 6   6/21/2022 at 19:21 (766 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1151956 , Reply# 7   6/21/2022 at 21:44 (766 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Early on as with h-axis had mechanical controls, this applied to both commercial/industrial and domestic.
By sometime in 1970's or maybe sooner or later both began seeing advances in "electronic" controls. This often may have been both mechanical timer combined with electronic controls. Soon virtually everything was and now is electronically control fully. This is a very good thing! Fully controlling drum movements, motor, and other bits via electronics allows not only far more variation of cycles than strictly mechanical timer, but better overall results. My older Miele is built like a tank, and nearly heavy as one in part to counter forces generated by machine. It will spin OOB loads that it probably shouldn't and modern machines certainly wouldn't. OTOH watching my new AEG Lavamat cope with OOB loads is a a treat. It will vary drum movement, motor and other bits to break up clumps and otherwise get loads properly distributed. |
Post# 1151957 , Reply# 8   6/21/2022 at 22:02 (766 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Were the 1964 through 1988 Westinghouse front load pairs.
As mentioned the Neptune stack built from 2000 to 2006 and the Frigidaire frontload stacks built from about 1997 to 2011 are partly mechanical and partly electronic.
The best frontload full size stack by far the Speed Queen‘s you can get the earlier ones that had all knobs on them but they also did have a board for the motor control and for the controls and the current ones are all electronic with an even greater capacity with the washer.
We have a couple of the earlier Speed Queen‘s around the shop that we could rebuild and sell if you wanted to come and get one someday.
John L |
Post# 1151965 , Reply# 9   6/21/2022 at 22:46 (766 days old) by sarahperdue (Alabama)   |   | |
Post# 1151968 , Reply# 10   6/21/2022 at 23:40 (766 days old) by sarahperdue (Alabama)   |   | |
Post# 1151975 , Reply# 11   6/22/2022 at 00:14 (766 days old) by sarahperdue (Alabama)   |   | |
Post# 1151989 , Reply# 13   6/22/2022 at 05:13 (765 days old) by ozzie908 (Lincoln UK)   |   | |
Would it pay you to have a water softener fitted to remove all the calcium and other crud? It may pay in the end as you would have to use less descaler and time spent cleaning filters etc... Also it would help your appliances live longer and give better results.
Along with nicer tasting water :) Austin |
Post# 1152026 , Reply# 14   6/22/2022 at 13:33 (765 days old) by sarahperdue (Alabama)   |   | |
Never! The water from my grandparents' well is the best tasting water on the planet when the system is getting a lot of usage. It tastes too "limey" when we haven't been down in a while. Otherwise, it's wonderful.
So, I have mixed feelings about a water softener. Interestingly, a friend here in the Tuscaloosa had one installed to deal with excess iron in her water. It's better on the fixtures, but she misses the taste. Hm, maybe I should have our water tested. So, y'all chime in--water softener or not? Thanks, Sarah |
Post# 1152027 , Reply# 15   6/22/2022 at 13:35 (765 days old) by sarahperdue (Alabama)   |   | |
Post# 1152031 , Reply# 16   6/22/2022 at 13:57 (765 days old) by kenc (SF Bay Area)   |   | |
Hi Sarah, It is AFNE9BSP113TW01 |
Post# 1152052 , Reply# 17   6/22/2022 at 17:03 (765 days old) by DADoES (TX, U.S. of A.)   |   | |
