Thread Number: 90918
Encore Pro Commerical Washer |
Post# 1154280   7/14/2022 at 09:49 (743 days old) by Chetlaham ![]() |
Post# 1154292 , Reply# 1   7/14/2022 at 13:31 (743 days old) by DADoES ![]() |
![]() 2
![]() The info sheet, which is tied via different .pdf file names on ALL the Additional Resources - From the Manufacturer link choices, references laundrylux.com as the warranting manufacturer. The About Us info there references Swedish Wascator, which became Wascomat in North America, which was bought by Electrolux in 1973, then became Laundrylux circa 2007. |
Post# 1154294 , Reply# 2   7/14/2022 at 13:50 (743 days old) by Chetlaham ![]() |
Post# 1154298 , Reply# 3   7/14/2022 at 15:24 (743 days old) by GELaundry4ever ![]() |
What cycles and temps are available? |
Post# 1154310 , Reply# 4   7/14/2022 at 18:00 (743 days old) by DADoES ![]() |
![]() Documentation says four cycles. Normal Cold, Normal Warm, Normal Hot, Delicate. Normal cycles are LOW wash fill, full cold agitated rinse. Delicate is cold with higher wash fill and reduced agitation (whatever that means, either action or time or both), and a full rinse. Heavy Duty option increases wash time, not available on Delicate. Extra Rinse option. Manager service mode programming options for shower rinse on all cycles to lessen water usage, or a forced additional Rinse on all cycles. Low and High fill levels can be adjusted in service mode. Setting the service mode additional Rinse, plus selecting the user Extra Rinse option may provide three rinses but that isn't explicitly stated. On-Premise version (not coin-op) has a Rinse and Spin by pressing Extra Rinse without first choosing a cycle. |
Post# 1154314 , Reply# 5   7/14/2022 at 18:27 (743 days old) by GELaundry4ever ![]() |
I'd use either of the 3 normal cycles depending on what color I'm washing. What is the time for the normal cycles at factory default? |
Post# 1154340 , Reply# 7   7/15/2022 at 07:02 (742 days old) by GELaundry4ever ![]() |
It would be nice if wascomat made commercial laundry for the home, including the encore models. |
Post# 1154355 , Reply# 8   7/15/2022 at 11:37 (742 days old) by DADoES ![]() |
![]() 2
Post# 1154357 , Reply# 9   7/15/2022 at 12:39 (742 days old) by pro104 ![]() |
It is made by Haier |
Post# 1154361 , Reply# 10   7/15/2022 at 13:29 (742 days old) by WindRivers (Wind River Range, WY)   |   | |
Haier is making "commercial" washers for Laundrylux? How do you know that? I can't find anything about it offhand, but then I can find very little on that particular washer. |
Post# 1154373 , Reply# 11   7/15/2022 at 16:10 (742 days old) by DADoES ![]() |
![]() The Encore's agitator and basket are reminiscent of F&P (which is owned by Haier since 2012), including the plastic basket base with bumps around the perimeter.
Post# 1154375 , Reply# 12   7/15/2022 at 17:15 (742 days old) by GELaundry4ever ![]() |
What's the capacity of the encore washer? How well do they perform? |
Post# 1154377 , Reply# 13   7/15/2022 at 17:55 (742 days old) by WindRivers (Wind River Range, WY)   |   | |
2.9 cu. ft. (82L) (Click on any of the "Additional Resources" on the link above for the specs.) I would guess it cleans about as well as any top loader with a standard (not dual action) agitator, but I don't know of anyone with actual experience with it, or its Haier sibling if there is one. |
Post# 1154395 , Reply# 14   7/15/2022 at 23:52 (741 days old) by Launderess ![]() |
Post# 1154431 , Reply# 15   7/16/2022 at 15:52 (741 days old) by pro104 ![]() |
I've seen those Encore Washers labeled Haier for residential sales, but only the front load version. Wascomat markets them but there is no claim to making them. |
Post# 1154478 , Reply# 16   7/16/2022 at 19:45 (741 days old) by nmassman44 (Brooksville Florida)   |   | |
The thing is that on the LaundryLux website they dont show the top loaders or maybe I wasn't looking in the right place there. Didn't Haier come out with residential laundry some time ago that had this agitator ? For some reason I remember seeing that the agitator is actually an "Agipellor" where it moved at high speed to achieve the wash action needed. The wash basket hole pattern is the same that they used in those machines as well.
Post# 1154480 , Reply# 17   7/16/2022 at 20:21 (741 days old) by DADoES ![]() |
![]() I don't find the toploader washer mentioned anywhere in the production information pages but there is a Top Load Washer Operating Manual. |
Post# 1154516 , Reply# 18   7/17/2022 at 10:33 (740 days old) by Chetlaham ![]() |
