Thread Number: 91374
I just found a 1937 Bendix Washing Machine! |
Post# 1158778   9/5/2022 at 18:52 (598 days old) by Sandxssun (Redlands, CA)   |   | |
I picked this up today. I couldn’t help it. Of course I didn’t need it, but damn was it cool looking. It appears to be a late 30s early 40s Bendix washing machine.
Amazingly clean for her significant age. No disrespect intended. Yes, she will be for sale. I just don’t know how much. I just brought her home today so I don’t even know her model number. Any help would be appreciated. And yes, I can ship her. I can pretty much ship anything. And possibly willing to deliver within Los Angeles or a state or so  So Cali. Hooray, I saved another one! |
Post# 1158799 , Reply# 1   9/5/2022 at 19:59 (598 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1158858 , Reply# 2   9/6/2022 at 07:19 (598 days old) by turquoisedude (.)   |   | |
Post# 1158862 , Reply# 3   9/6/2022 at 08:18 (598 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1158866 , Reply# 4   9/6/2022 at 09:17 (598 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Post# 1158892 , Reply# 5   9/6/2022 at 12:47 (598 days old) by swestoyz (Cedar Falls, IA)   |   | |
This is a great save! A 1938 thru 1940 model S, Standard. Fully automatic model with the revised soap dispenser cover (bake-lite vs. the earlier brushed chrome cover, seen below). You may find a serial tag behind the front cover, on the frame below the cleanout. Model tag should be on the rear cover, near the bottom. A 'Bendix Home Laundry' badge should also be on the lower front panel, as well.
Ben Quick footnote. Folks often use a date of 1937 when showing early, pre-War Bendix washers. The only model that was available specifically in the fall of '37, when the Bendix was debuted, is the full one piece wrap around cabinet, porcelain top, galvanized tubs, white painted timer/temp dial escutcheons, and a white drop down door (vs. the side opening door). By early '38 the wrapper cabinet was broken down to three pieces and the drop down door color was changed to black enamel paint.
This post was last edited 09/06/2022 at 13:04 |
Post# 1158970 , Reply# 6   9/7/2022 at 07:57 (597 days old) by swestoyz (Cedar Falls, IA)   |   | |
Quick observation - I suspect this particular Standard does not have the original style 'Bendix Home Laundry' badge at the bottom of the lower panel due to the updated soap dispenser cover having the name cast within the bake-lite lid/cover. If the OP/seller doesn't mind posting a photo of the model tag and/or serial number tag, it would be greatly appreciated.
This is a beautiful washer. Hopefully someone here saves it. Ben
Post# 1158972 , Reply# 7   9/7/2022 at 08:50 (597 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Anywhere close to 500, plus I don’t even own anything anywhere in Los Angeles so it’s not like I could bolt it down anyway, I really do hope someone here can save it |
Post# 1158980 , Reply# 8   9/7/2022 at 09:32 (597 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 1158988 , Reply# 9   9/7/2022 at 10:54 (597 days old) by 2011hoovermatic (owosso michigan)   |   | |
Question how much did the bendix cost in 1937? Thanks. |
