Thread Number: 91719
/ Tag: Member Selling Item(s)/Non Professionally
Maytag A506 washer for sale for repair or parts |
Post# 1162411 , Reply# 1   10/24/2022 at 14:45 (550 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1162413 , Reply# 2   10/24/2022 at 15:05 (550 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 1162415 , Reply# 3   10/24/2022 at 15:14 (550 days old) by qsd-dan (West)   |   | |
Post# 1162436 , Reply# 4   10/24/2022 at 18:47 (550 days old) by Maytag85 (Sean A806)   |   | |
I actually fired up my Maytag A806 since it had been sitting for a few months but wasn’t agitating even though the motor was running, a short while later it started to squeal. Stopped the machine, laid the drain hose down to drain the water, removed the front panel, propped the machine up on a paint bucket, moved the drive belt by hand and that fixed that. The belt had simply developed a flat spot on the motor and just wasn’t wanting to move. Simply by rocking and moving the belt around corrected that issue.
Post# 1162438 , Reply# 5   10/24/2022 at 18:51 (550 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1162460 , Reply# 7   10/25/2022 at 00:30 (549 days old) by Maytag85 (Sean A806)   |   | |
Hi John, I’ll just rephrase what I said in reply #4. Basically a belt that has flat spots from sitting for awhile can cause it to not agitate or spin and since it went from 100 degree wether to about 70 and 60 something degrees, it caused the belt to develop a flat spots which caused my Maytag A806 to not want to agitate at all at first. Since rocked the belt and moved it by hand, that fixed that issue. To be sure the upper bearing wasn’t locked up, I ran it through a quick cycle and there were no ill sounds or effects and completed the quick test cycle. If a Maytag doesn’t want to agitate at all for sitting for a few months or a year, more than likely the belt needs a little coaxing by hand to get it to move.
