Thread Number: 91800
/ Tag: Wanted to Buy Items
Spare Maytag belts anyone? |
Post# 1163394   11/7/2022 at 16:33 (535 days old) by Awooff (Peoria, Illinois)   |   | |
Hi all! My daily A108, in 2004 had a new set of whirlpool belts. Well im getting a knocking noise thru spin regularly now, maybe a new set of belts would quiet this. Its had somewhat heavy use in last 20 years.
Wanted to ask if any of you are in surplus of a set of belts? 47 bucks on repairclinic and have no problem paying - just seeing if anyone had a surplus out there? |
Post# 1163396 , Reply# 1   11/7/2022 at 16:56 (535 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1163406 , Reply# 2   11/7/2022 at 18:23 (535 days old) by LowEfficiency (Iowa)   |   | |
Post# 1163415 , Reply# 3   11/7/2022 at 21:08 (535 days old) by qsd-dan (West)   |   | |
I'd remove and inspect the belts before condemning. Knocking issues during the spin cycle are generally not the belts. It's usually the damper pads, tub bearing, loose tub to suspension arm bolt(s), bleach or water pressure hose banging into the cabinet, broken suspension eye bolt, tub cover contacting the inner tub, and inner tub knocked off center.
Post# 1163435 , Reply# 4   11/8/2022 at 10:44 (535 days old) by Awooff (Peoria, Illinois)   |   | |
Thanks for replies as each has me thinking more on this. Last i looked a year ago, the damper pads looked ok.
The knocking sounds to me sound like the slide plate (also replaced in 2004). Also on full loads, "a tick" sound is heard while washing, different but similar sound during spin. After reading here more, maybe a perfect leveing job would correct this - currently the machine slopes back slightly. |
Post# 1163730 , Reply# 5   11/12/2022 at 15:11 (531 days old) by Awooff (Peoria, Illinois)   |   | |
Post# 1163732 , Reply# 6   11/12/2022 at 15:14 (531 days old) by Awooff (Peoria, Illinois)   |   | |
