Thread Number: 91858
/ Tag: Modern Dryers
2006 Duet Dryer Repair |
Post# 1163828   11/13/2022 at 16:04 (621 days old) by DADoES (TX, U.S. of A.)   |   | |
Of the Duet set I refurbed in Nov 2012 (washer) and Mar 2013 (dryer) for one of RJ's rental properties. Third tenants currently in-residence. Complaint: Made a grinding noise, heats but doesn't dry, door window collects condensation. Diagnosis: Blower off motor shaft, threads on shaft worn down, blower threads OK. Procedure: Replace motor (used via eBay) and clean machine interior of lint. Note: The washer thus far has had no repairs post-refurb (other than clearing the pump trap of debris twice for the current tenants). The dryer has had a couple/three previous repairs. |
Post# 1163831 , Reply# 1   11/13/2022 at 16:40 (621 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1163856 , Reply# 2   11/13/2022 at 18:34 (621 days old) by DADoES (TX, U.S. of A.)   |   | |
Pic 2 is the new/used motor, shipped with a hub insert from a broken blower (or maybe it's a screw-on cap of some sort?). The 3rd pic has it removed. The Duet dryer's original blower wheel (no pic of it) looked to be intact, and it it seemed to screw securely on to the replacement motor.
Pic 1 is the damaged threads on the original motor. Or are the threads on the blower hub damaged and that's remnants of it embedded into the motor shaft threads? There doesn't seem to be a workable way to get the original motor's shaft threads cleaned if so. Did I misinterpret the situation and the blower wheel also needs to be replaced? I've not before dealt with this problem. |
Post# 1163858 , Reply# 3   11/13/2022 at 19:17 (621 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1163873 , Reply# 4   11/14/2022 at 00:08 (620 days old) by DADoES (TX, U.S. of A.)   |   | |
John, thanks for the education. I've ordered a blower wheel. The motor is already replaced, it was less than $45. For future reference, would a new blower attach securely onto the original motor with the threads obstructed as seen in Pic 1? What's your recommended method to clean up the motor shaft threads if not? |
Post# 1163881 , Reply# 5   11/14/2022 at 08:39 (620 days old) by ryner1988 (Indianapolis)   |   | |
The used appliance shop from which I bought my current Whirlpool DD TL washer also had a duet approximately the same age as my machine, around 16 years old. I almost purchased it instead, but I heard all the horror stories about bad spiders in FL washers and I didn't want to take a chance on one that old. Now I sort of wish I had. Apparently those duet washers can last a real long time if taken care of properly. The above post is an example of this.
Ryne |
Post# 1163882 , Reply# 6   11/14/2022 at 09:13 (620 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1163897 , Reply# 7   11/14/2022 at 12:36 (620 days old) by DADoES (TX, U.S. of A.)   |   | |
Thanks, John. There's a wire brush on the bench grinder in dad's garage workshop. Ryne, this pair was bought used in late summer 2012 for one of my neighbor's rental properies. He needed a stackable set for the location. The dryer was on Craigslist. The seller said that the washer had problems so he had bought a new pair. The described problem didn't sound serious, I figured I could repair it. The washer was left at the local dealer, the seller said he could probably get it back and include it with the dryer at the same price. It was filthy. The pump was shot and the pump trap clogged with so much debris there's no way it was draining. The drum spider was intact but deteriorating. I decided to go full-meal-deal, replace the drum (spider not separately available) and bearings. Renters are horrible on appliances. I wrote-up instructions how to run the hidden tub-clean cycle but they rarely do it, if ever. Wife of the current occupant family complains constantly about everything. Claims that she and daughter have mold allergies, wants the HVAC ducts cleaned. They're getting more mold exposure via their laundry than from the air conditioning, LOL. She uses questionable detergent, once proudly showed me a bottle of a boutique liquid, touting the wonderful lavender scent. The washer has thus far kept running along so that must be a testament to something. |
Post# 1164129 , Reply# 8   11/17/2022 at 17:48 (617 days old) by DADoES (TX, U.S. of A.)   |   | |
