Thread Number: 91950
Best Spray Rinse Coverage |
Post# 1164901   11/26/2022 at 09:02 (608 days old) by chetlaham ![]() |
Post# 1164933 , Reply# 1   11/26/2022 at 12:42 (608 days old) by qsd-dan (West)   |   | |
![]() 3
Probably a Frigidaire 1-18. Pre '94 Maytags and pre 90's GE FF's had a nice wide spray pattern with long spray rinse intervals. Pre neutral drain Norges (early 1960's) had a one minute spray rinse before and after the deep rinse.
CLICK HERE TO GO TO qsd-dan's LINK |
Post# 1164949 , Reply# 2   11/26/2022 at 15:51 (608 days old) by chetlaham ![]() |
Post# 1165014 , Reply# 3   11/27/2022 at 14:22 (607 days old) by BlockEight88 ![]() |
![]() 2
Post# 1165023 , Reply# 4   11/27/2022 at 15:03 (607 days old) by chetlaham ![]() |
Post# 1165024 , Reply# 5   11/27/2022 at 15:15 (607 days old) by qsd-dan (West)   |   | |
Post# 1165025 , Reply# 6   11/27/2022 at 15:26 (607 days old) by BlockEight88 ![]() |
![]() 2
Post# 1165027 , Reply# 7   11/27/2022 at 15:48 (607 days old) by chetlaham ![]() |
Love it!
I bet with several more of those you could even skip the deep rinse. Flow rate is excellent. I like how it starts before the spin as the clothes accelerate. Though it it were me, I'd have the water going for a full minute. ;) You're lucky to have a machine like this, best all around washer ever made IMO. |
Post# 1165034 , Reply# 8   11/27/2022 at 16:06 (607 days old) by BlockEight88 ![]() |
Post# 1165036 , Reply# 9   11/27/2022 at 17:33 (607 days old) by chetlaham ![]() |
Turning it on and off would be nice feature. A switch with multiple rinse options would be best with a name like "ultimate rinse system" You could select a combination of sprays, one deep rinse, two deep rinses or all combination of all.
I think all Whirlpool machines should have done a rinse in each spin, but for some reason they only did it in the last spin. |
Post# 1165049 , Reply# 10   11/27/2022 at 19:25 (607 days old) by DADoES ![]() |
![]() Classic belt-drive Whirlpool/Kenmore did four sprays in the first spin and two in the final spin ... touted as seven rinses with the agitated rinse being one of the seven. I vaguely recall a video of a Kenmore doing four sprays in the final spin. F&P's spray flume has excellent coverage of the load. |
Post# 1165050 , Reply# 11   11/27/2022 at 20:00 (607 days old) by DADoES ![]() |
![]() 2
![]() I recently bought a water flow meter to check usage. First test, I washed three black t-shirts and a black sweatshirt/hoodie in the AquaSmart on Normal Eco. Default Eco-Rinse, which is saturation sprays at 25 RPM, each followed by an extraction spin. 3.8 gals for eco active 0.4 added for oversudsing (3-1/3 tbsp Foca powder + 1 tbsp STPP) 5.1 gals added (to minimum level*) for HE agitated wash drain slow spin-extract (300 RPM) 1.0 gal 1st spray slow spin-extract 1.0 gal 2nd spray slow spin-extract 1.0 gal 3rd spray slow spin-extract 0.9 gal 4th spray med spin-extract (670 RPM) 1.0 gal 5th spray med spin-extract 0.9 gal 6th spray final spin 9.3 gals total for wash fill 5.8 gals rinsing 15.1 gals total cycle *Basket float is normally the trigger for the HE wash level but it occurred before the minimum level was reached so fill continued to the minimum level. |
Post# 1165051 , Reply# 12   11/27/2022 at 20:01 (607 days old) by combo52 ![]() |
![]() 2
Were the Kenmore and Whirlpool direct drive top load washer with the resource saver spin rinsing system.
Mine does six separate rinses starts out with fresh water which is proportion to the amount of clothing in the machine. It will use anywhere from about a half gallon to 2 gallons per rinse and then it continues to recirculate the water over the clothing through the other side of the flume For one minute, and it repeats this six times. The old belt drive machines had to pulse the spray rinse on and off because they were filling at the rate of over 9 gallons a minute, that’s twice to three times the flow of a Maytag washer, depending on the age or Ge Filter Flow, etc. If anybody wants a better rinse and faster, fill on the direct drive machine, you can put the yellow belt drive inlet valve in most of them it’s bolts right in and you’ll get incredible amount of water. A tub will fill up in anywhere from 2 to 3 minutes depending on whether it’s the standard or super capacity machine when it’s set on warm. John |
Post# 1165054 , Reply# 13   11/27/2022 at 20:36 (607 days old) by qsd-dan (West)   |   | |
![]() 3
No deep rinse on the resource saver spin rinsing? I think I'll pass on that but it's a unique idea. It will get the detergent out of the clothes but it's a good idea to have a deep rinse to agitate any lingering dirt/stains out of the clothing.
I'm assuming these are the water valves you're referring to? https://www.ebay.com/itm/283102645684QUE... |
Post# 1165057 , Reply# 14   11/27/2022 at 21:36 (607 days old) by combo52 ![]() |
There is a deep rinse cycle that could be manually selected after the regular cycle if you feel like you need an additional rinse, I guess if you had a load that was really full of grit and lint, it might be helpful. I’ve never used it.
That looks like the inlet valve I’m talking about I think the part number was 358277 I don’t think the one in the link you posted is a genuine, whirlpool valve, and I’ve seen a lot of problems with imitation valves. I try to steer clear of them. John |
Post# 1165065 , Reply# 15   11/28/2022 at 10:16 (606 days old) by chetlaham ![]() |
The resource saver was and is ingenious, its a shame it never caught on. I think had it caught on, TL washers could have been produced for longer. And Whirlpool wouldn't have resorted to things like 1/3 fill deep rinses like in the late 2000s.
Thank you for the part number John, I was looking for that. I might just put one of those on my Speed Queen, I never liked the slow fills in comparison to the DDs I had 12 years ago. Here is the commercial for the Resource Saver: And a video (not mine) of the full cycle: |
Post# 1165186 , Reply# 16   11/29/2022 at 23:00 (605 days old) by GELaundry4ever ![]() |
GE filter-flo! |
Post# 1165727 , Reply# 17   12/5/2022 at 21:57 (599 days old) by chetlaham ![]() |
