Thread Number: 91951
strange Danby DWM99-W washer |
Post# 1164903   11/26/2022 at 09:08 (608 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
i am hoping that the fine folks can answer the question i have
I took the back off to see if i could put a different drain hose on I do not think that can be done as the drain port on the pump is very small compared to other washers But the dilemma I have is when i looked inside and saw 2 pressure stitched and hoses one pressure switch hose goes from the tub to a y fitting with 3 port another pressure hose goes from one port on thy fitting up thru the machine up into the control panel where the pressure switch that controls the water level with the water level knob But one pressure hose goes from one port up to the right hand side of the machine where there is another what looks like a pressure switch This pressure switch has a screw on it I have tried to research it but cannot find anything on documentation to see what this is I'll pause this for now |
Post# 1165079 , Reply# 1   11/28/2022 at 16:29 (606 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1165391 , Reply# 2   12/2/2022 at 13:15 (602 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1165400 , Reply# 3   12/2/2022 at 14:03 (602 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
well i got it to operate
BUT and this is a big but I had to jury-rig the safety system I put a rubber washer used in washer hoses to seal them in the lid switch mechanism this makes the safety lid switch engaged all the time so the lid switch mechanism may not stop the washer if the load is unbalanced i hope the fine members can add to this thread |
Post# 1165572 , Reply# 4   12/4/2022 at 13:30 (600 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1167575 , Reply# 5   12/26/2022 at 17:55 (578 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1167623 , Reply# 6   12/27/2022 at 02:00 (577 days old) by jil1000 (Northern CA )   |   | |
