Thread Number: 91982
/ Tag: Ranges, Stoves, Ovens
Induction Speed and Controllability |
Post# 1165316   12/1/2022 at 12:05 (523 days old) by Marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
I've just shot this video here in Dublin showing the time taken to bring exactly one litre/one kilogram of water to the boil from 20 ℃ (71 ℉) on this particular hob. Spoiler alert: it took just over 2 minutes. I also test how quickly it reacts when adjusting the power level.
I will be back in Palm Springs next week and will make another video of the same test on my gas cooktop. Will be interesting to see what the difference is. Anyone care to hazard a guess?!
Mark
Post# 1165329 , Reply# 1   12/1/2022 at 15:00 (523 days old) by joeekaitis (Rialto, California, USA)   |   | |
. . . using the Power Boost setting on the largest zone in a 6-quart pressure cooker bottom with its glass lid. The water hit a full boil before the 10-minute Power Boost timeout. Under 10 minutes is pretty darn fast.
Control response is the same as in the video. If a pot of pasta is about to foam over on High, it immediately settles down on 9 and keeps boiling without foaming. |
Post# 1165357 , Reply# 2   12/1/2022 at 23:49 (523 days old) by SudsMaster (SF Bay Area, California)   |   | |
I found this video to be helpful. I actually worked for about a year for a cabling outfit and we did some electical stuff as well.
Post# 1165360 , Reply# 3   12/2/2022 at 01:06 (523 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1165369 , Reply# 4   12/2/2022 at 07:34 (522 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1165372 , Reply# 5   12/2/2022 at 09:10 (522 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1165375 , Reply# 6   12/2/2022 at 10:00 (522 days old) by joeekaitis (Rialto, California, USA)   |   | |
Post# 1165399 , Reply# 8   12/2/2022 at 13:57 (522 days old) by vacerator (Macomb, Michigan)   |   | |
in the video doesn't say why a reveresed polarity wired outlet is dangerous. |
Post# 1165448 , Reply# 9   12/2/2022 at 21:59 (522 days old) by SudsMaster (SF Bay Area, California)   |   | |
Mike,
I can think of at least one reason why a reversed polarity outlet could be dangerous.
And that is because if the on/off switch in an appliance only controls the "hot" wire, then the appliance might not shut off when the switch is put to the off position, if the hot and neutral wires are reversed, and there is another path to ground.
Also, if another electrician comes along and starts working on a circuit with reversed polarity, that electrician could get shocked by the neutral wire if it's connected wrong.
Another problem would involve light sockets. Normally the hot circuit is attached to the little electrode at the bottom of the socket, and the neutral circuit is attached to the outer part of the socket, which is usually threaded to match the light bulb. But if the polarity is reversed, then one could get a shock from the outer portion of the socket.
I remember when I worked for a year for an electrical contractor. One of the kids he hired kept on wiring the outlets wrong, reversing hot and neutral. The contractor wound up firing the kid.
Post# 1165456 , Reply# 11   12/3/2022 at 02:16 (522 days old) by SudsMaster (SF Bay Area, California)   |   | |
Post# 1167017 , Reply# 13   12/18/2022 at 23:33 (506 days old) by Marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
Post# 1167132 , Reply# 14   12/20/2022 at 20:15 (504 days old) by SudsMaster (SF Bay Area, California)   |   | |
So what? The key to good cooking is not speed, but what I would call gentility. That is, gentle heat, applied judiciously, yields better results for most foods. And for those where a lot of heat is desirable, there are countertop appliances that work well, like rice cookers.
Not saying induction is bad, but it does require a cooking utensil that responds to magnetic impulses. So it would require replacing most aluminum cookware. Gas works with anything. |
Post# 1167137 , Reply# 16   12/20/2022 at 21:17 (504 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1167151 , Reply# 17   12/21/2022 at 07:06 (503 days old) by joeekaitis (Rialto, California, USA)   |   | |
Post# 1167160 , Reply# 18   12/21/2022 at 09:50 (503 days old) by norgeway (mocksville n c )   |   | |
Is something i will never have because Im not giving up my aluminum cookware, All my cookware stainless and aluminum is vintage and Im used to it. |
Post# 1167165 , Reply# 19   12/21/2022 at 11:06 (503 days old) by appnut (TX)   |   | |
I didn't opt for induction for the sole purpose of speed. In fact, I rarely use power boost or even the highest setting under boost. I selected induction because of safety, ease of cleaning and ability to maintain a reliable slow simmer and simiar attributes as well as flexibility/accuracy similar to gas.
Post# 1167207 , Reply# 21   12/22/2022 at 06:28 (503 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It’s always great to be able to heat things quickly. That’s why chefs have such large powerful ranges, but it’s not the only thing in cooking. Of course you’re right about that Rich.
In addition to the easy clean ability of an induction range one of the wonderful things is, they’re completely safe it’s impossible to start a fire on an induction cooktop, which is not a bad thing when you consider that many of us on this thread are approaching our golden years and are getting forgetful.
About the only other range ever made were the original corning cooktops witch were completely safe, because all four burners had a thermostat, and it was impossible to badly burn things or start a fire on those as well.
As far as cookware anything that’s magnetic works well. Some of my favorite cookware is my mothers 1950s Echo Flint stainless steel that I use every day on my induction stove.
I generally try to not cook in aluminum not because it’s unsafe but as Rayjay said it can impart a bad flavor to food and most of all it’s not good in the dishwasher and I generally don’t use anything in the kitchen that doesn’t go in the dishwasher.
John. |
Post# 1167215 , Reply# 22   12/22/2022 at 09:38 (502 days old) by appnut (TX)   |   | |
I have an Ecko Fint 2 quart pan with double boiler insert that was my grandmothers. I was pleasantly surprised it worked. I kinda wish I had a whole set of that stuff, meaning eveery major piece they offered back in the day. And with balance issues, I feel much safer with the inducton vs. how I began feeling when I still had my old coil burner stove and fear of falling onto one of those burners.
Post# 1167226 , Reply# 23   12/22/2022 at 14:00 (502 days old) by CircleW (NE Cincinnati OH area)   |   | |
Bob, my former Thelma had a set of Ekco Flint cookware. It's a tri-ply type, so not surprised it works on an induction cooktop. Yesterday I was looking at a Vollrath tri-ply SS fry pan, and it said it is induction compatible. |
Post# 1167230 , Reply# 24   12/22/2022 at 15:00 (502 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1167245 , Reply# 25   12/22/2022 at 17:49 (502 days old) by SudsMaster (SF Bay Area, California)   |   | |
Post# 1167270 , Reply# 26   12/22/2022 at 22:42 (502 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
