Thread Number: 92081
Is this SQ worth buying? |
Post# 1166335 , Reply# 1   12/11/2022 at 17:49 (593 days old) by chetlaham ![]() |
The best modern washer money you can buy, and one of the best washers ever made over all. I know because I own a Speed Queen. I love it! I love how clean it gets things, the gracious sounds, the luxury performance, reasonably gentle, a true hand-wash cycle, fast cycle times and good rinsing.
Down side is this model does not fill with the lid open and has no water level selector. But if you're washing full loads, by all means this machine is for you. If not, you could always swap the control panel for one with a water level selector: https://www.ebay.com/itm/115520887075QUE... https://www.ebay.com/itm/275558527281QUE... |
Post# 1166338 , Reply# 2   12/11/2022 at 18:00 (593 days old) by panasonicvac (Northern Utah)   |   | |
![]() 2
Post# 1166346 , Reply# 3   12/11/2022 at 18:29 (593 days old) by ryner1988 ![]() |
I think you should get the machine. Speed Queen is one of the only options I would consider if I had to get a new washer, aside from maybe LG and in that brand I would only consider the front load model with turbo wash. Speed Queen makes great machines in both top and front load configuration so I don't think you could really go wrong with this model.
Post# 1166390 , Reply# 4   12/12/2022 at 07:47 (592 days old) by huebschman (Quebec, CA)   |   | |
For $250!!! Even with the lack of water control I would get it and have it stored until my Heubsch ZWN432 gives in or for the spare parts. For cryin' out loud go for it!!! Can you tell us where you got this deal? |
Post# 1166430 , Reply# 5   12/12/2022 at 18:45 (592 days old) by GELaundry4ever ![]() |
Hurry up and buy it! |
Post# 1166480 , Reply# 6   12/13/2022 at 13:44 (591 days old) by BlockEight88 ![]() |
Post# 1166491 , Reply# 7   12/13/2022 at 16:05 (591 days old) by ryner1988 ![]() |
I don't think that can happen because the TC 5 is an electronic machine. Even though it's mostly a dial configuration, there is a control board behind the knobs as well as a board that controls the transmission. On the 2017 model, a mechanical timer essentially tells the transmission when to engage/disengage different parts of the cycle. So I do not think they are interchangeable.
Post# 1166492 , Reply# 8   12/13/2022 at 16:26 (591 days old) by BlockEight88 ![]() |
Post# 1166500 , Reply# 9   12/13/2022 at 20:31 (591 days old) by combo52 ![]() |
Can you swap out the control panel etc. from a TC5 and put the earlier mechanical controls on a TC five?
YES you may need the entire wiring harness but the machines mechanically are exactly the same so you could find an old worn out even 15 or 20 year old Speed Queen mechanically controlled washer and put the control panel and wiring harness on a TC five it would plug right in. The motor etc. is all exactly the same as the older machines with mechanical timers. John |
Post# 1166503 , Reply# 10   12/13/2022 at 21:08 (591 days old) by ryner1988 ![]() |
Interesting, I would not have thought that could be done because the transmission on the TC5 also has a control board, or so I figured.
Guess you learn something new every day. This is why I like this site so well, so informative. Even though I'll likely never be able to work on washers myself, the wealth of knowledge here is fascinating. |
Post# 1166533 , Reply# 11   12/14/2022 at 08:21 (590 days old) by BlockEight88 ![]() |
According to someone on YouTube who just purchased a TC5003 with the matching dryer, SQ has designed the lid switch to throw an error code if it doesn't detect and opening. Here is what he said:
This method DOES NOT work on new machines purchased on or after June 2022 anymore. After doing 4 loads with the lid switch bypassed and the Machine does not see the lid being opened, it will error out and if you call speed Queen for service and they find out you have bypassed it, THEY WILL VOID YOUR WARRANTY. |
Post# 1166534 , Reply# 12   12/14/2022 at 08:39 (590 days old) by DADoES ![]() |
Post# 1166536 , Reply# 13   12/14/2022 at 09:33 (590 days old) by BlockEight88 ![]() |
Post# 1166540 , Reply# 14   12/14/2022 at 10:21 (590 days old) by combo52 ![]() |
Ever since the TC top load models came out a few years ago you have not been able to bypass the lid switch because of the electronic control on this model. This is not a new design change. You can always just wire in a toggle switch on the back of the control panel so that you can watch the machine and keep the computer. Happy, I did this on my Calypso, which is 20 years old so that I can watch the machine.
Bypassing a lid switch, etc. will not void the warranty automatically. Warranty Work is done by independent contractors for Speed Queen they would have to demonstrate that you damaged the machine so if you bypass the lid switch and it has a bad water pump, the replacement water pump would still be covered. John |
Post# 1166543 , Reply# 15   12/14/2022 at 11:07 (590 days old) by BlockEight88 ![]() |
Post# 1166602 , Reply# 16   12/15/2022 at 00:20 (589 days old) by panasonicvac (Northern Utah)   |   | |
![]() 2
I'd always bypass the lid switch on my Kenmore and even my parent's old GE top loader as well, no issues whatsoever. Never bypassed the lid switch on any of the Speed Queens that I've used before but I'd assume I also wouldn't have any issues if I were to get a TC5 or any old school SQ top loader. I did thought about getting a TC5 but now I'm leaning towards on getting a FF7 because as a consumer, I'd be better off with one of those instead. At least for a primary washer since I'd love to have a top loader as my secondary washer or something I'd use once in a while. We'll see though.
