Thread Number: 92082
/ Tag: Modern Dryers
How to Disassemble Miele T1 Heatpump Dryer |
Post# 1167188 , Reply# 1   12/21/2022 at 17:59 (583 days old) by richnz (New Zealand)   |   | |
Post# 1167248 , Reply# 3   12/22/2022 at 18:12 (582 days old) by mielerod69 (Australia)   |   | |
Hi Nathan,
You should keep a look out for the older T8000 series heat pump dryers. I have a T8929WP and wouldn't swap it for a new Miele T1. I had a Miele T1 heat pump and gave it to my mum as it took longer to dry and the bed sheets would ball up. The T8000 series has two motors, one for the drum and one for the fan, so you get proper reverse tumbling. Also, the T8929 has a gentle tumble option which pauses the drum from rotating whilst the fan is still moving the air through. I see some of the older Miele heat pumps come up on Facebook marketplace. Rod |
Post# 1167249 , Reply# 4   12/22/2022 at 18:39 (582 days old) by Launderess ![]() |
Post# 1168287 , Reply# 8   1/4/2023 at 09:09 (569 days old) by foraloysius ![]() |
Post# 1168454 , Reply# 12   1/6/2023 at 08:30 (567 days old) by Logixx ![]() |
Post# 1168465 , Reply# 13   1/6/2023 at 13:37 (567 days old) by henene4 ![]() |
"Supposed to" is probably the right word - all I can say is that all I know is that nothing internal points towards a 2023 release. |
Post# 1168468 , Reply# 14   1/6/2023 at 14:54 (567 days old) by Logixx ![]() |
Post# 1168530 , Reply# 16   1/7/2023 at 06:56 (566 days old) by Logixx ![]() |
Post# 1168821 , Reply# 20   1/9/2023 at 05:31 (564 days old) by Logixx ![]() |
That was an interesting video.
Now, I'm not quite sure if running the dryer without the side panel is an accurate way to measure the temp inside the drum. Even running my old Siemens condenser without the water tank would result in (very slightly) lower temp due to the increased cooling air flow - and that dryer had like four times the heating power of the heat pump. Also, and this could be a auto translation error, but he said that BSH dryers never reversed, don't do it right now and probably never will. None of this is true. In the end, I'd suggest you go to Amazon and get yourself some thermometers. Mine cost next to nothing and are similar to this www.amazon.com.tr/ARCELI-... |
