Thread Number: 92349
/ Tag: Classified Ad Finds
The Holy Grail of Kenmore |
Post# 1169488   1/14/2023 at 19:58 (470 days old) by UltraWash (Charlotte, North Carolina )   |   | |
Greetings AW family, hope everyone is doing well. I thought you guys would like this. CLICK HERE TO GO TO UltraWash's LINK |
Post# 1169489 , Reply# 1   1/14/2023 at 20:16 (470 days old) by appnut (TX)   |   | |
Post# 1169491 , Reply# 2   1/14/2023 at 20:22 (470 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1169492 , Reply# 3   1/14/2023 at 20:24 (470 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1169493 , Reply# 4   1/14/2023 at 20:25 (470 days old) by appnut (TX)   |   | |
Post# 1169494 , Reply# 5   1/14/2023 at 20:27 (470 days old) by appnut (TX)   |   | |
Post# 1169500 , Reply# 6   1/14/2023 at 21:05 (470 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1169501 , Reply# 7   1/14/2023 at 21:06 (470 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1169505 , Reply# 8   1/14/2023 at 21:28 (470 days old) by LowEfficiency (Iowa)   |   | |
How did that dryer work? I see a "fabric selector" on the left with a seven-position switch. Then what looks like four status lights (drying, cool down, and two things I can't read in the photos...) Then a block of six buttons for "electronic all fabric" from less dry to more dry, three buttons for "timed dry" (20, 40, and 60 minutes?), and a button for "Wrinkle Guard III"? A variable signal control from "off" to "hi"... And a chunky "Start" / "Off" control, which looks like it might move up and down? Prominent "Solid State" markings, in two places it looks like... |
Post# 1169507 , Reply# 9   1/14/2023 at 21:49 (470 days old) by drummerboy928 (Illinois)   |   | |
Post# 1169510 , Reply# 10   1/14/2023 at 22:55 (470 days old) by appnut (TX)   |   | |
Post# 1169511 , Reply# 11   1/14/2023 at 23:05 (470 days old) by appnut (TX)   |   | |
Turned the slide switch to turn on power, changed fabric selector if desired, pushed button for appropriate sensor dry or timed dry, and pushed start. Dryers with this style panel were usually very deceptive regarding fabric selector--usually only high, low, and ar temps. I only knew the real LKs had medium dry temps. Durimg this "center dial" generation, LKs only had the 3rd dry temp.
Post# 1169557 , Reply# 12   1/15/2023 at 10:25 (469 days old) by DADoES (TX, U.S. of A.)   |   | |
Cropped and tweaked photos of the consoles. Dryer Fabric Selector (temp) has choices of Cotton Sturdy, Perm Press, Touch Up, Knit, Delicate, Air. Signal lights for Drying, Cool Down, Wrinkle Guard, and Lint Screen. Cycle buttons are arranged in three designated sections. - Electronic All Fabric (moisture sensor) has six choices left-to-right from Less Dry to More Dry. The 4th button is tagged with a dot or asterisk which may indicate Normal Dry. - Timed Dry has Touch Up 20, 40, or 60 mins. - Last button on the right end is Wrinkle Guard III option. Variable adjustment for end of cycle Signal volume, Off to Hi. Up/down toggle switch for Start and Off. There's a dot or asterisk between Knit and Delicate on the Fabric Selector, no labeling for what it means. Maybe it matches to the tag on the one cycle button? Whirlpool's version of this dryer had more choices on the cycle buttons. A toggle switch to the right side selected Auto Dry or Timed. The entire range of buttons operated for both choices, labeled for auto dry levels above the buttons and timed below them. Wrinkle guard was tied to the temp buttons, Perm Press and Knits. The washer's console (3rd pic) is impossible to make clear. |
Post# 1169568 , Reply# 13   1/15/2023 at 11:09 (469 days old) by appnut (TX)   |   | |
Post# 1169569 , Reply# 14   1/15/2023 at 11:10 (469 days old) by appnut (TX)   |   | |
Post# 1169571 , Reply# 15   1/15/2023 at 11:15 (469 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1169573 , Reply# 16   1/15/2023 at 11:39 (469 days old) by appnut (TX)   |   | |
Post# 1169695 , Reply# 17   1/16/2023 at 10:55 (468 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow, this dryer only has five marked temperatures on the dial it actually has an infinite temperature control.
The control system on this dryer is completely electronic, while the whirlpool version of this machine had more buttons on it this Kenmore version is actually more versatile, you can add the wrinkle guard on any cycle on this dryer and it has more temperatures, the whirlpool version had more timed dry settings that was its only advantage. This was a very good dryer, not the prettiest thing they ever made however, it was a real come down from the Lady Kenmores built earlier. John |
