Thread Number: 92350
LG WM3600 cycle times are SLLOOOOWWWWWW. |
Post# 1169521 , Reply# 1   1/15/2023 at 01:06 (468 days old) by appnut (TX)   |   | |
The large load of towels, what cycle did you use? I can give you a whole litany of explanation of cycles. I have an LG4500 and it's not much different than your 3600.
Normal & Heavy Duty, the heater does not come on at all except for extra hot temperature. For heavy duty cycle, hot is regulated incoming to 112F; warm is regulated at 90F max. On Normal, hot is regulated to 90-95F max. Warm is regulated to 84-86F. For Whites, Perm Press, Towels, and Bulky/Bedding, Hot is maximum of 112F, once that temp is reached heater turns off and doesn't come on to mtaintain temp. Warm is 90F max and no heater to mataintain temp. Steam option of Bedding and Whtes, hottest temperature at heaviest soil temp is targeted at best to 158-162F. Sanitize cycle, max temp is 155-158F. Steam on Sanitize is 158-162. If you used the Towels cycle for your large load f towels, the 57 minutes was about the max wash time and again is restricted to a max of 112F. For daily loads of general clothes, I use Perm Press and warm and adjust spin speed depending upon fabric. When using extra hot on Normal or Heavy uty, there is no target temperature. If temp maxes out before end of wash phase (155-158) heater shuts off and waits until drain for main wash. I think it's stupid Towels doessn't offer extra hot, but that cycle is also intended for washing jeans and denim. When I wash towels, I just use Normal or Heavy Duty, extra hot temperature and heaviest soil level (for longest amount of water heating) and add the maximum extra rinses. Depending upon just how hot I want extra hot to get, I will vary the soil level from lowest to soil level just above normal soil level to vary heating time. Today I did a good size load of flannel lounge pants,jersey long-sleeve t-sirts, and sox on Normal, Hot (so I could have 95F-104F "warm water wash", normal soil level, and 2 extra rinses (and Turbowash is default to on) and extra high spin speed. the load sensed and yielded cycle time of 1:30. By the time the load was finished, it had reduced the cycle time by 16 minutes. I used the quick wash once and only once. It does no spins between wash and any rinses and only spins for the final spin. totally useless as far as I'm concerned. I"ll use Normal wash and lightest soil level. I"ve actually found Perm Press to be faster than Normal for a quick washon lightest soiil level and no or 1 extra rinse compared to normal with the same options. I just realized your model doesn't offer TurboWash. And to be honest, that feature makes a big difference in cycle length. I can tell a difference in cycles when I don't use that option if it's not forced on. This post was last edited 01/15/2023 at 01:35 |
Post# 1169563 , Reply# 4   1/15/2023 at 10:54 (467 days old) by appnut (TX)   |   | |
Ken, I share your frustation particularly with the heater not mtaintaining temp. The WP Duet I had for almost 11 years could do exactly that--maintain temp once reached during wash phase. The LG is simply designed differently. A former member here, who is as obsessed as me, provided me with some of the target temp information he'd put together and then I built upon that. He has had nothing but LG washer for the past 10-15 years. To see what water temperature is you can push the delay wash and then add temp button at the same time. Display will show temperature in C, not F. Deay wash and spin will show spin speed rpm.
A week ago,. I did two separate loads of towels. One was 6 terry bath mats I use to put outside my shower and the other load was 10 sets of bath towels, cloths, and hand towels. The settings were exactly the same for both loads, but the towel load after sensing was 58 minutes more for the heavy load. My home's electrical system is based upon 208V rather than standard 220/240V. It impact heating, making it take longer. It's never been an issue with me as the Duet compensated for the additional time to heat. the Duet had specified temps. Warm 95-100, Hot 127, Allergiene 131, and Sanitize 158. I have to admit, I couldn't remember if the 3600 had TW or not as I remember the 3600 was released before the 3900. This series was LG's new Turbowash 360 design. Yes, I've noticed misleading information regarding features in online reviews too. |
Post# 1169591 , Reply# 5   1/15/2023 at 13:38 (467 days old) by kenc (SF Bay Area)   |   | |
appnut, Thanks for the temp and spin display info, I shall try that. I just put in a load - heavy duty - hot wash (not extra), normal soil, extra fast spin and it still says 2Hours! So it's not extra hot which determines the extra time. |
Post# 1169599 , Reply# 6   1/15/2023 at 15:33 (467 days old) by appnut (TX)   |   | |
Post# 1169607 , Reply# 7   1/15/2023 at 16:51 (467 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 1169614 , Reply# 9   1/15/2023 at 17:38 (467 days old) by appnut (TX)   |   | |
Ken, are you using extra high spin speed on normal or heavy duty? If so, yes they extend the final spin. I've reverted to usig extra high spin speed because my electricity rate increased in September so I welcome the long spin for towels and other cottons.
Yes Mark, I"m stil happy with my LG now that I've got many of the idiocyncracies worked out. |
Post# 1169621 , Reply# 10   1/15/2023 at 19:17 (467 days old) by kenc (SF Bay Area)   |   | |
appnut, Yes, until experimenting today, I've used extra high spin exclusively, I didn't know it mean extra long duration as well? What are the various spin speeds? |
Post# 1169625 , Reply# 11   1/15/2023 at 20:15 (467 days old) by ryner1988 (Indianapolis)   |   | |
Honestly, the more I hear about this washer, both here and elsewhere, the more I would love to have one. Makes me wish I would have sprung for it instead of buying the used DD. The DD works for my household but I think this machine could be great.
I can't imagine ever not using Turbo Wash on it though. Is there ever an occasion when you don't use it, or do you just leave TW enabled at all times? I don't think I would buy the model without it, that would be a deal breaker for me. Also, do you think I could learn how to keep track of the cycles on the dial and eventually learn how to set them independently? I know I would need the app for the touch panel portion as that's completely visual, but I'm wondering if I could learn to count clicks on the dial to which cycle I want. For instance, if I'm understanding right, I know that the first turn to the right after turning the washer on is always normal, no matter where you left the dial last. So I'm wondering if I could work this machine by counting clicks from that point, for instance, four clicks after normal is always heavy duty, or something to that effect. Then use the phone to make modifications. I LIKE MY DD because it's so easy for me to set that old-school type of washer non-visually and independently, but I know I'm going to have to face this electronic reality eventually. |
Post# 1169683 , Reply# 13   1/16/2023 at 06:15 (467 days old) by mrboilwash (Munich,Germany)   |   | |
Matt, I think you`re wrong on this one.
I does make a lot of sense to temper the incoming water and then reheat it at least if cleaning efficiency is a priority. Even if the enzymes in a detergent aren`t bothered that much up to 60°C/140°F some stains are certainly altered by 150°F incoming water thus becoming harder or even impossible to shift. You could easily remove the worst nightmare blood stains with a 1950s Miele in a boil wash cycle using a simple no enzyme 1950s detergent but this would always involve a cold start to warm prewash followed by again a cold start boil wash. There`s a good reason for not starting with the desired target temperature! It only makes sense to start warm if central water supply is much cheaper than heating the water in the washer or if heating in the washer would take forever like in the USA because of the low Voltage system and then it`s still a compromise. As much as I favor 95°C washes, if I had to deal with a washer depending on incoming water temperature only I`d never go above 120°F. |
Post# 1169697 , Reply# 14   1/16/2023 at 10:57 (466 days old) by petek (Ontari ari ari O )   |   | |
I have the wm3700 and we only use the Reg or Heavy Duty cycle 90% of the time. I have noticed that the initial time given often drops a good 10 or 15 minutes somewhere during the cycle, maybe more. As for the Speed Wash (15 minutes) I like it and use it frequently for 2 or 3 items like a pair of jean and a couple of Tees. It's set for a low soil level but you can nudge it up so that it adds more wash time plus you can add a second rinse etc. I have no complaints with the machine, dirty clothes go in and clean clothes come out.
Post# 1169722 , Reply# 17   1/16/2023 at 16:25 (466 days old) by mark_wpduet (Lexington KY)   |   | |
I wonder what the wash times are on the Whirlpool and Maytag FL washers? I know they all have recirculation (from what I've seen)... whereas LG has turbo wash on "certain" models only...
I guess it's all what you get used to and working things out... I remember when I first got my Duet... I HATED it... I was sooo disappointed.. but I knew I had to work with it and I ended up slowly falling in love with it. Now I dread the day it dies. It would be awesome to have a FL washer that used the same voltage as the dryer...Most people in American probably never heard of a boil wash... I'm jealous of Euro washers sometimes. |
Post# 1169725 , Reply# 18   1/16/2023 at 16:47 (466 days old) by appnut (TX)   |   | |
Jay, thank you for the information.
Ken, you are correct, selecting steam negates any control of soil level as well as temperature. AND when steam is selected, you cannot do a prewash. I tried steam once and that was it. Usually, when I need the highest temperature possible, the load also requires a prewash to not set th4e various food stains. I discovered by accident the downloaded Denim cycle and selecting extra hot and heaviest soil level, results in a wash phase that's 45 or 50 minutes longer than Sanitize with heaviest soil or Heavy Duty with extra hot and heaviest soil. That extra time allows for water temperature heating to reach 158-162/163. One "benefit" of my house saddled with 208V, allows me to have some variation of hot water temperatures ranging from 135 to 162 degrees based upon cycle selected and minimum to maximum soil levels. Have I mentioned just how much I detest the standard (energy star) hot water tempearture set point design of 112 max as detestable? I mean, back when washer had a "medium" wash temp in the 1950s, that thermostatically was a whopping 120 degreees, a nice midpoint between 100 and 140 degrees for warm and hot water temps. Thus my profound appreciation and respect for European decades-old "boil washes" that results in bright whites and stains being obliterated with oxygenated bleach detergents. Results I personally never attained with liquid chlorine bleach. |
Post# 1169726 , Reply# 19   1/16/2023 at 17:21 (466 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1169762 , Reply# 20   1/16/2023 at 22:38 (466 days old) by appnut (TX)   |   | |
John, I've already provided the information you are seeking about LGs in this thread and in other threads I've contributd regarding LGs since I got mine October 2021. I could have responded last night, but I thought you would have seen what I've written in this thread plus previous threads. I'm probably the one who has literally sat in front of my LG through cycles than anyone else.
Post# 1169764 , Reply# 21   1/16/2023 at 23:01 (466 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Oh yes, I’ve read your extensive posts on your 4500 and greatly appreciate them. However, I remember reading Mike’s post on his 4000 and him stating that if you choose warm, the washer maintains that temp. However on yours, I believe you stated it does not maintain temps just gets them there and the heater shuts off. So, I’m wondering if it possibly has to do with the programming for 5.0 tubs vs programming for 4.5 tubs?
Post# 1169766 , Reply# 22   1/16/2023 at 23:38 (466 days old) by appnut (TX)   |   | |
John, I very seriously doubt there's any difference due to basic programming across the platforms. I will admit once warm is heated to 90F on PP, Whites, and Bulky that the temp will maintain during a 12-15 minute wash on normal soil.
I also just checked the energy star yellow tag for both the 4000 (4.5 cu ft) and 4200/4500 were all a rating of 105 kwh, so no difference in usage thus same programming. |
Post# 1169787 , Reply# 24   1/17/2023 at 11:12 (465 days old) by appnut (TX)   |   | |
Ken, no you don't need to pause the cycle in order to ccheck the tempor spin speed. I do this all the time. Touch the delay wash area on the panel with a finger on my left hand and while holding the touch on delay wash, with my right hand finger touch the temp or spin area on the panel to display water temp or spin speed. Sometimes touching the delay wash area of the panel will cause a "ding" sound but that doesn't mean it's locked out. I jus go ahead and touch the temp area despite the delay wash area dinging at me.
Post# 1169789 , Reply# 25   1/17/2023 at 11:33 (465 days old) by petek (Ontari ari ari O )   |   | |
Post# 1169793 , Reply# 26   1/17/2023 at 12:05 (465 days old) by kenc (SF Bay Area)   |   | |
appnut: yes, that's what I was trying. The machine did not respond. I also checked the phone app in case that functionality had moved, but no. |
Post# 1169794 , Reply# 27   1/17/2023 at 12:24 (465 days old) by appnut (TX)   |   | |
Post# 1169795 , Reply# 28   1/17/2023 at 12:36 (465 days old) by kenc (SF Bay Area)   |   | |
I tried the app in desperation! I tried quick touches, and long holds, nothing worked last time. Maybe the 3600 lacks this functionality? |
Post# 1169887 , Reply# 30   1/19/2023 at 12:28 (463 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 1169913 , Reply# 32   1/19/2023 at 19:57 (463 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 1169971 , Reply# 33   1/20/2023 at 16:57 (462 days old) by kenc (SF Bay Area)   |   | |
Does the water adjustment trick work on the latest generation of LG washers then? Or have they taken care of that like all big corporations tend to do? If so, I will be doing this one day after my 1 yr warranty expires. |
Post# 1169975 , Reply# 34   1/20/2023 at 18:54 (462 days old) by kenc (SF Bay Area)   |   | |
Tried it again: the 3600 does not respond to delay+temp or delay+spin. No doubt a firmware "upgrade" |
Post# 1169982 , Reply# 35   1/20/2023 at 19:56 (462 days old) by appnut (TX)   |   | |
Post# 1170086 , Reply# 36   1/22/2023 at 02:10 (461 days old) by Egress (Oregon)   |   | |
Odd, my WM3900 does respond to the delay+temp trick, I wonder if its a different button combination for some reason? unless its a recent firmware change... |
Post# 1176505 , Reply# 39   3/29/2023 at 23:18 (394 days old) by appnut (TX)   |   | |
Post# 1176509 , Reply# 40   3/29/2023 at 23:50 (394 days old) by powerfin64 (Yakima, Washington)   |   | |
Bob and I both have the WM4200.
your machine also weights your load WEIGHT and based on your soil level chosen, which determines your cycle time. Heavy Duty is a great cycle, it is a longer cycle for very soiled loads, along with Extra Hot, which I use frequently. Turbo Wash is just a name. It does what it's supposed to do, helps speeds up the cycle, which I use with all cycles also. Your machine is doing exactly what it is supposed to do. |
Post# 1176555 , Reply# 41   3/30/2023 at 13:25 (393 days old) by nmassman44 (Brooksville Florida)   |   | |
I have the LG 4000 washer and dryer and my washer does not vibrate like this...then again I have a concrete floor and its not on a pedestal either. I find the shortest cycle times on the Normal cycle with TurboWash. The longest cycle and painfully so is the Towels cycle which I rarely use. The two cycles used most by me are Normal and Bright Whites. Both cycles use AI and it amazes me how well that works. I also use the High Speed spin setting as well with no issues. I have had my washer and dryer now for almost 2 years and they have performed flawlessly. In fact every LG appliance I have ...washer, dryer, fridge, electric range, dishwasher and microwave have been trouble free and all perform quite well.
