Thread Number: 92369
Whirlpool Frontload Washer with Timed Dry Button |
Post# 1169745   1/16/2023 at 19:18 (466 days old) by DADoES (TX, U.S. of A.)   |   | |
Visiting a Lowe's today, there is a Whirlpool frontload washer with a TIMED DRY button. I don't know the model number. I didn't take a photo. I asked the sales girlie, she said it's a dryer. Nope, it's a washer, see here, the detergent and softener dispenser drawer and the Drain & Spin button, a dryer would not have a Drain & Spin function. She, confused, went to check documentation somewhere, probably at Lowe's website, came back and said there's nothing about a Timed Dry button. The matching dryer was sitting atop it, also with a Timed Dry button in the same position on the button array. Did I find a factory production line foul-up, the wrong button overlay on it? |
Post# 1169758 , Reply# 1   1/16/2023 at 20:09 (466 days old) by ryner1988 (Indianapolis)   |   | |
Post# 1169759 , Reply# 2   1/16/2023 at 20:33 (466 days old) by petek (Ontari ari ari O )   |   | |
Post# 1169765 , Reply# 3   1/16/2023 at 23:12 (466 days old) by appnut (TX)   |   | |
Post# 1169767 , Reply# 4   1/16/2023 at 23:43 (466 days old) by CleanteamofNY ((Monroe, New York)   |   | |
12-Hour FanFresh® Option Keep clothes fresh for up to 12 hours after the wash cycle has ended. A built-in fan activates after the wash cycle is over, tumbling clothes for up to 12 hours so you can finish laundry when you're ready.
Wash and Dry Option Let the washer keep laundry moving for you by adding this option to select wash cycles. After washing ends, it uses hot air to tumble dry clothes right in the washer.4
Whirlpool is using the exhaust of the dryer to heat the washer by a deflector valve or something. Anyway, the online reviews on the Whirlpools website are a no go for me. One of my YouTube influencers had a Whirlpool appliance nightmare. All of his brand-new appliances broke down.
CLICK HERE TO GO TO CleanteamofNY's LINK |
Post# 1169770 , Reply# 5   1/17/2023 at 01:35 (466 days old) by DADoES (TX, U.S. of A.)   |   | |
Bob, I don't think it's a combo, the price didn't register to my attention as high enough unless it's mis-labeled. The Timed Dry selection is on the bottom of the array of center black buttons, I believe in the same position as on the dryer stacked atop of it. There may be an opportunity to get photos in about 3 weeks. |
Post# 1170374 , Reply# 6   1/26/2023 at 00:57 (457 days old) by Joe_in_philly (Philadelphia, PA, USA)   |   | |
It appears to be a combo with condensing dryer. For the price ($1394.10), it sounds like a bargain! The owner’s manual (found on the page linked below) seems incomplete and has hardly any info in it.
Description Do laundry the way you want in a large capacity all in one washer dryer that installs virtually anywhere. Whether your laundry area is a closet or mud room, fit this space saving washer dryer combo and wash, dry or wash and dry all in one appliance. Plus, skip adding detergent to every load with the Load & Go™ XL Dispenser. Wash & Dry Option Wash and dry an average sized load in 3.5 hours, all in one appliance. All-In-One Washer & Dryer Whether you need to only run a wash cycle, just dry a few items or wash and dry a whole load, the All-In-One Washer & Dryer gives you the flexibility to do your laundry the way you want. Space-Saving Design Closet, mud room or full-size laundry area—no matter what your space, take up less room and do laundry in one appliance instead of two. With a ventless Space-Saving Design and 33" installation depth, the All-In-One Washer & Dryer can be installed virtually anywhere with a water hookup. Largest Available Capacity in Its Class at 4.5 Cu. Ft. (Among full size All-In-One Washer & Dryer brands.) With the Largest Available Capacity in Its Class at 4.5 Cu. Ft., this All-In-One Washer & Dryer provides enough room for day-to-day loads, while still fitting in the space that’s convenient for your family. Intuitive Controls Let the All-In-One Washer & Dryer guide you to the right cycle combinations or customize up to 41 of your own wash and dry cycles to get the right type of fabric care for whatever you wash and dry. CLICK HERE TO GO TO Joe_in_philly's LINK |
Post# 1170401 , Reply# 7   1/26/2023 at 13:50 (457 days old) by appnut (TX)   |   | |
Post# 1171661 , Reply# 8   2/8/2023 at 21:50 (443 days old) by DADoES (TX, U.S. of A.)   |   | |
