Thread Number: 92414
/ Tag: Vintage Dishwashers
soap door won't open automatically |
Post# 1170320 , Reply# 1   1/25/2023 at 13:22 (464 days old) by maytaga806 (Howell, Michigan)   |   | |
I would think this is a mechanical opening dispenser, looks far too old to have a wax motor but I could be wrong? My late 90s styled powerclean had the same issue, needed a new wax motor and all was good. Check owners manual if available online somehow, see part diagrams to find out how the dispenser works and go from there someone on here I’m sure will give all that to you.
Post# 1170321 , Reply# 2   1/25/2023 at 13:23 (464 days old) by cfz2882 (Belle Fourche,SD)   |   | |
-that is what was wrong with my 1974 KA-a bad connection developed at the bi-metal strip behind dispenser: easy fix :) |
Post# 1170481 , Reply# 5   1/27/2023 at 05:01 (462 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You may have a bad dispenser assembly, does the lid still spring open if the dispenser is sticking, you either need to replace the dispenser assembly or take it apart and try to rebuild it. They were not meant to be serviced, but some people have successfully done it.
You may also have a bad buy metal on it. You’ll have to take the other door off and inspect look for burned wires, or a partly broken bimetal latch. John |
